Keep your Skid Plates tuned!
Old Jul 29, 2011 | 04:54 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default Keep your Skid Plates tuned!
C5 or C6 Fangs are only $49.99 includes free shipping in the USA!
Note: There may be a shipping charge to a few areas of the US where there is no standard mail delivery.
The Fangs are the best Lower Radiator Support/ Skid Plate protection on the market and a small price to pay to protect an expensive part of your Vette!
Here are some of the advantages of having Fangs.
1)They distribute the load over the entire skid plate where it is the strongest and can evenly distributes the impact, not on one side or the other where the side load can bend skid plate.
2)The superior performance plastic we use is 6 times more abrasion resistant than steel making them slide very smoothly over what ever they come into contact with.
3)They perform perfectly in hot or cold weather.
4)They are only 1/8” thick so there is no noticeable ground clearance loss.
5)There are no moving parts to wear out.
6)They only weigh 5oz for those that worry about weight.
7)On the C5’s there is no drilling or modification needed to install them. The C6 requires four small holes (about 1/8”) and we supply the drill bit and the stainless steel self tapping screws for threading the hole along with Four Stainless Steel Black Oxide coated screws to secure the Fangs.
8)The Fangs give protection over the entire skid plate. So if you bump up on a parking block like we demonstrate in our video you are protected from the front to back and from the highest point of the skid plate to the lowest. They don’t look like you just bolted something on to your skid plate, they look like they belong.
Don't wait till you scrape!
C5 link
http://www.saccitycorvette.com/Fangs.html
C6 link
http://www.saccitycorvette.com/C6-Fangs.html
And if you want to watch a couple videos of us abusing
the Fangs. The scraping sound you hear is the air dam not the Fangs.
http://www.saccitycorvette.com/See-t...n-Action-.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Aug 1, 2011 | 06:20 PM
SacCityCorvette
Supporting Vendor
Fangs Bump!
Old Aug 3, 2011 | 01:13 PM
SacCityCorvette
Supporting Vendor
ttt
Old Aug 7, 2011 | 05:01 PM
SacCityCorvette
Supporting Vendor
Bumping the Fangs!
Old Aug 7, 2011 | 05:14 PM
bearcatt's Avatar
bearcatt
I'm going to order a set of them right now!
I was down there the other day replacing my radiator and doing an oil change... OMG!.. I need these!
It cannot be overstated how important these fangs are.
Old Aug 9, 2011 | 11:48 AM
SacCityCorvette
Supporting Vendor
Thanks bearcatt, we agree with you 100%!
Old Aug 12, 2011 | 04:49 PM
SacCityCorvette
Supporting Vendor
Fangs weekend bump!
Old Aug 12, 2011 | 05:33 PM
siberian.mist's Avatar
siberian.mist
do these replace the originals or are they just covers? different colors available?
Old Aug 12, 2011 | 06:16 PM
SacCityCorvette
Supporting Vendor
Hi siberian.mist,
They are covers that protect your original skid plates/lower radiator support from damage. They come in black and white.
Old Aug 17, 2011 | 12:37 PM
SacCityCorvette
Supporting Vendor
Don't wait till you scrape your skid plates, again!
Old Aug 19, 2011 | 03:34 PM
SacCityCorvette
Supporting Vendor
bump it to the top. Have a great weekend
Old Aug 19, 2011 | 06:11 PM
bearcatt's Avatar
bearcatt
Thanks for getting those fangs out to me.
I was out of town and just got in the other day.
Just the fangs installed to prevent damage to my radiator support.
Very easy install.
Old Aug 23, 2011 | 12:28 AM
SacCityCorvette
Supporting Vendor
Your welcome bearcatt! And thank you, we appreciate your business!
Old Aug 24, 2011 | 12:08 PM
camburger's Avatar
camburger
I bought a set of fangs and installed them last Saturday. I'm satisfied they will work as intended.
My install experience was not easy though for a few reasons. First I made the error in not lifting the car high enough to achieve working and visual comfort...therefore I struggle to "feel" my way through the assembly...again my error there. Recommend this be done on a much higher lift than a block of 2x12 wood.
Second was the fact my clearence around the frame extention was biased to one side leaving me zero space to push the Fang onto the front end as noted in the instructions. There was no forcing it to happen either as the materials involved in both the fang and the bumper are tough and unyielding under average hand effort. I studied it for a while as I lay on my back, and came to the conclusion that some prying force was needed to open up space on that one limiting side. I had though about filing a greater clearence, but the file would never have fit either. A screw driver and some awkward manipulations eventually made the gap large enough and I was finally able to jam the fang in place up front and snug it up onto the rest of the extention as per instruction. This was on the drivers side.
The passenger side was similar but not quite as difficult, but there was a limiting space bias towards one side nevertheless which did cause me the same general effort as did the drivers side.
I know for fact the install would be simple were the spacing even around those frame extentions.
That was my experience and is in no way a reflection of the products design or quality. It's a nice product and will serve it's function very well I'm sure.
Bob
Old Aug 25, 2011 | 05:38 PM
SacCityCorvette
Supporting Vendor
Hi camburger,
Thanks for your purchase and letting us know how your install went.
Out of all the Fangs we have sold you are only the second person that we know of that
had a bit of a clearance issue. I'm glad you got it worked out!
Old Aug 26, 2011 | 07:56 PM
SacCityCorvette
Supporting Vendor
Don't forget to keep it cool with the Cool It v2 and v3!
http://forums.corvetteforum.com/c5-p...-corvette.html
http://www.saccitycorvette.com/COOLITv2.html
Old Aug 31, 2011 | 05:52 PM
SacCityCorvette
Supporting Vendor
GOT FANGS!
To Keep your Skid Plates tuned!
Old Sep 3, 2011 | 03:44 PM
SacCityCorvette
Supporting Vendor
Bumping for the Labor day weekend!
Old Sep 8, 2011 | 05:34 AM
SacCityCorvette
Supporting Vendor
Get your Fangs before you scrape your skid plates again!
Old Sep 9, 2011 | 08:02 PM
SacCityCorvette
Supporting Vendor
ttt
