changed bcm but now have code b2721hc
Old Jul 29, 2011 | 05:16 PM
luvmystere's Avatar
luvmystere
Cruising
Default changed bcm but now have code b2721hc
I changed my bcm on a 1999 now still wont start. and it will not unlock steering column. code reads b2721hc on the bcm. I had the bcm flashed to my vin#
thanks for the help
Old Jul 29, 2011 | 07:13 PM
luvmystere's Avatar
luvmystere
Cruising
how can i find out how to do that pcm relearn
Old Jul 30, 2011 | 12:13 PM
luvmystere's Avatar
luvmystere
Cruising
Default bcm/pcm relearn process. Iwent through it and now it
Originally Posted by 8VETTE7
You need to start with a good battery that is fully charged or you will have to repeat this lengthy process again after the battery gives up:
BCM/PCM RELEARN PROCEDURE
Start with a fully charged battery or you might drain the battery BEFORE the procedure is completed. It's long enough without having to start over.
You will need to conduct the PCM/BCM relearn process. This matches their handshake ID's and allows them to talk to each other.
Do this before you worry about VATS issues:
1. Turn on the key for 11 minutes.
2 Turn off the key for 30 seconds.
3. Repeat 1&2 two more times.
4. Turn on the key for 30 seconds.
The car should start and run with the new BCM. Good luck.
This will sync the PCM to the New BCM but all of your RPO options will not be retained. You will need a TECH II to program them into the new BCM.
I went through relearn now it will start but I get service steering column and Iget bcm codes b2528 witch is column lock/unlock and pcm codes p1626 theft det learn mode active and p1630 theft det start enable signal not correct thanks
Old Jul 30, 2011 | 12:17 PM
lucky131969's Avatar
lucky131969
Hmmmm....two threads on this ......
http://forums.corvetteforum.com/c5-t...e-b2721hc.html
Old Jul 30, 2011 | 01:39 PM
luvmystere's Avatar
luvmystere
Cruising
Go in and manually clear all the codes:
http://www.c5forum.com/ayc/dtcdic.php
then start the car and pull the codes again. See what returns.
I manually cleared all codes . now the only ones I get are bcm 2588 and 2593 witch are column lock and unlock thanks
Old Jul 30, 2011 | 01:41 PM
luvmystere's Avatar
luvmystere
Cruising
Originally Posted by lucky131969
hmmmm....two threads on this ......
sorry
To changed bcm but now have code b2721hc
