Sunvisor replacement or recover them
Old Jul 29, 2011 | 05:43 PM
31coupe's Avatar
31coupe
Default Sunvisor replacement or recover them
Being a new member here I am sure this subject has come up before but the sunvisors on my 2003 Anni (slate color) needs replacing. Has anyone found a good replacement or have they just had them recovered. If so was it possible to save the mirrors or were they recovered without mirrors.
Also the way they are removed looks easy but is it?
Old Jul 29, 2011 | 08:15 PM
woodman300's Avatar
woodman300
St. Jude Donor '15
those are good questions. i have the same problem with mine. the passenger side needs to be recovered. i was thinking about getting some leather and sewing them myself. that way i can get the look i want and i won't have the stupid warning on it. i was also thinking about adding the little garage controller i have seen on some of the later model visors.
Old Jul 30, 2011 | 11:37 AM
31coupe's Avatar
31coupe
I went to an upholstrey shop and they can recover in a similer material and I am sure they will look just fine. He wasn't sure he could put the mirrors back in as he wasn't sure how they were mounted inside. That really would not be a real big deal, but getting them out of the car was up to me. I have seen the step by step process on the interent but....I really don't have good luck sometimes and it is a plastic clip. There is a store on the interent that sells all colors except mine. thank you for responding and good luck with yours.
To Sunvisor replacement or recover them
