Help! Climate Control Question!
Old Jul 30, 2011 | 11:02 AM
bigmatt22's Avatar
bigmatt22
Navigator
Default Help! Climate Control Question!
My 99 blows ice cold air out of the passenger side and cool air from the drivers side. I have read many threads on how to fix this and I realize the freon could be low or the actuator could be bad. I have tried resetting the actuators and I can hear them open and close....but I have a issue that I did not notice in these threads.
Is it typical when an actuator goes bad that the driver's side control **** controls the passenger temp? I can make my passenger nice and toasty and ice cold when I turn the **** on the drivers' side but it doesn't affect the driver's side temperature nor does the passenger side **** do anything.
I just wanted to know if you guys had seen this before? Could it be the actual climate control head unit? I live in South Carolina and we have had 3 weeks of 100 degree weather and it is driving me crazy. Like I said the driver's side air is cool but it never changes, it wont get hot or cold.
Any help would be appreciated!
Thanks,
Matt
Old Jul 30, 2011 | 11:34 AM
dmarkshark's Avatar
dmarkshark
Ok, see if this helps. The drivers side control is for both sides, the passanger side will only add or take a few degrees from what the drivers side is set at. So, I would suggest you check your freon charge? Also, check and see if you have any codes on the DIC that pertain to the HVAC.
Old Jul 30, 2011 | 04:01 PM
ThomasUSMC's Avatar
ThomasUSMC
im having a problem with the temps not changing. where are the actuators and how do u know there bad? how do u reset them?
Old Jul 30, 2011 | 04:12 PM
dmarkshark's Avatar
dmarkshark
Thomas USMC - It may be more helpful for you to start a new thread, and let us know what is going on, with more info.
Old Jul 30, 2011 | 05:30 PM
bigmatt22's Avatar
bigmatt22
Navigator
Yeah checking the freon levels will be my next step. I did have one code it was "B0441 H C Left Actuator Out of Range." It has not come back after I reset the actuators so hopefully it will stay that way. If not I will have to take it out and check it out. Thanks for your help! I'll post if the freon fixed it as soon as I can get someone over here to check it for me. Thanks again.
To Help! Climate Control Question!
