dumb question about Tick M/C install-Help
Old Aug 3, 2011 | 12:31 AM
Crabr1's Avatar
Crabr1
Default dumb question about Tick M/C install-Help
In the directions it says to remove spring on clutch pedal assembly,it doesn't say to reinstall it,are you supposed to? thats the last thing I have left to do so hopefully someone responds here real quick.TIA
Old Aug 3, 2011 | 05:32 AM
bumble-z's Avatar
bumble-z
You leave the spring out.
I suggest putting a dab of blue loc tite on the two bolts that hold the cylinder to clutch pedal bracket.
If you run into any problem, feel free to give me a pm.
Old Aug 3, 2011 | 12:37 PM
Crabr1's Avatar
Crabr1
Thanks,thats what I thought,I went ahead and finished the install and tried everything without the spring,it all works good,feels different but now my car doesn't creep when I put it in gear and reverse is easy to get again,I did do the blue loctite also.
Old Aug 12, 2011 | 05:37 PM
Joey@Tick's Avatar
0Joey@Tick
Former Vendor
Just to clear up any future confusion: our kit requires that you remove the spring and leave it out.
To dumb question about Tick M/C install-Help
