Stock ride height
Old Aug 3, 2011 | 04:03 AM
Txsailor's Avatar
Txsailor
Default Stock ride height
My car appears to be lowered the front bolts are backed out 1 7/16 from the spring to the top of the hex. I like the way it looks but really need it to be a little higher. It drags going in and out of my driveway and no matter how careful I am it drags a lot of places on our terrible streets. I have already damaged the air dam and will have to replace it.
My question is what is the stock setting and how much can I change it without having to make a alignment change?
Old Aug 4, 2011 | 11:29 AM
Txsailor's Avatar
Txsailor
Well I didn't receive a single answer so and I guess its because everyone thinks these cars should be as low as they can get them. Sorry for the terrible idea that I would like to return my car to its stock configuration. I guess I will just have to guess and hope I don't get it a millimeter higher than stick and risk the wrath of my fellow vette owners.
For some silly reason a stock height corvette with air dam in place the looks much better to me than a lowered one with a mangled air dam hanging down with the bottom edge torn up like a bunch of beavers have been chewing on it. I see those all the time and think " that guy sure doesn't look as cool as he thinks he does". Of course that's just me.
Old Aug 4, 2011 | 11:51 AM
The Beej's Avatar
The Beej
Whoa there skipper!!! A quick search of the tech forum or read the FAQ in stickies and you'll find your answer. I have to ask though your screen name is TXSailor, is it because your military by chance? If your at Carswell shoot me a PM and I can help you out with your ride height.
The Beej
Old Aug 4, 2011 | 11:53 AM
oh1vette's Avatar
oh1vette
Although you did say you didn't like the look, I've read others have trimmed thier air dams up to 1" with no effect on cooling......
Old Aug 4, 2011 | 01:47 PM
Txsailor's Avatar
Txsailor
The Beej
I did a search but could find nothing about where the factory sets the bolts. I suspect the po just lowered the front as the back bolts look untouched. I doubt he even had the alignment checked.
I raised it to about the middle of the bolts and that made it clear the driveway a little better. It also seemed to drive as well or better, that's why I think he just lowered it and didn't change the alignment.
I am not ex military just a old guy with a few sailboats. I do work close to you though. I work on the F-35 at Lockheed. We share your runway.
Old Aug 4, 2011 | 02:02 PM
hotwheels57's Avatar
hotwheels57
You should at least have the alignment checked if you alter the adjustment bolts from the current (lowered) settings. Your expensive tires will pay the price if you don't.
I also don't like the lowrider look, but I did lower mine on oem bolts and uncut bushings. It's only lowered 5/8" and 3/4" which is within the GM suggested parameters. Just changing the adjustment bolts that amount required an alignment after everything settled.
My car doesn't scrape except at the entrance to my steep angle driveway. The noise is just the center air dam. It's a reminder to go in at an angle/slower. I'd rather hear that than the undercarriage scraping like I'm certain some excessively lowered cars probably experience.
The air dam will self level itself in time or you can trim off a very small amount.
Old Aug 4, 2011 | 02:38 PM
Txsailor's Avatar
Txsailor
Default Thanks for the ideas...
I may trim a little off the bottom, Its already pretty worn looking anyway. One issue I have is the frame for the center piece was all bent back. I honestly don't know if we did that or it was that way when I bought it. I straightened it up the best I could but will probably replace it. Does it come with the replacement part or is it separate? If so who carries them?
Old Aug 4, 2011 | 03:13 PM
The Beej's Avatar
The Beej
Right on, I have a few friends that work over there. I myself have thought about going across the way but I like the stability of my current guard technician job. If you get bored or ever want a hand shoot me a PM and we can meet up, talk about planes, vettes or whatever.
Old Aug 23, 2011 | 03:21 PM
Six862m6's Avatar
Six862m6
I was really hoping to see some info here as well. I'm a relatively new owner to my C5 (Had it about a month now) and I'm pretty sure its been lowered by the PO as well. I know it has a set of Bilstein shocks that have been installed at all four corners, though when it was up on the lift and I I was looking it over, I didn't know what to look for when it came to the bolts. Now I do, I just need to get back under and look again. Regardless, I'm not too crazy about it being lowered myself but have no idea what the stock ride height is or even where it should be properly measured from? Surely there should be some suspension or frame location that the measurement should be taken from, I know body panels shouldn't be used as I'm sure they vary in height depending on the tolerances used to make and hang them. Most importantly, I don't think the PO kept the factory rake, which as we all know is not good at all! I've been doing some searches, but have been pretty unsuccessful at finding a post that actually gives some numbers and the correct locations to measure from. Any help would be much appreciated.
Best picture I currently have of it that might give you an idea of how it's sitting by looking at the gap between the wheels and fenders...
Old Aug 23, 2011 | 03:40 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Well for both of you...check the link out under the photos...it shows before and after shots of where the bolts should be in both stock and lowered form. Should help you get back to ground zero. Don't be afraid of what others say...it is totally by personal preference and every vette has it's own stance...this is why the bolts are there to begin with. Lets you dial or fine tune it.
http://www.frankhunt.com/FRANK/hobbi...5_Lowering.htm
Old Aug 23, 2011 | 03:47 PM
XtremeVette
Six862m6, your vette has definitely been lowered man. I would check and make sure you still have your bushings in fact. Sometimes the owners cut them right out to go even lower. In addition, check the length of your bolts...you might have the lowering bolts which are longer then stock...this too will allow the car to sit lower.
Old Aug 23, 2011 | 07:28 PM
Solofast's Avatar
Solofast
Here is a link to a thread that has the proper dimensions for measuring your ride height. Make sure you are on a flat surface when you do this. Most garage floors aren't flat enough to get a good measurement. It's best to do it on an alighment rack or a similar place.
http://forums.corvetteforum.com/c5-t...de-height.html
Old Aug 24, 2011 | 12:23 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
http://forums.corvetteforum.com/c5-g...s-lowered.html
http://forums.corvetteforum.com/c5-t...red-front.html
Old Aug 24, 2011 | 08:20 AM
Six862m6's Avatar
Six862m6
Thanks for the info guys, you're helping me along witht this. XtremeVette- I jacked up both ends of the car last night and got a good look at the bolts. The rears LOOK factory like the one in the pic you posted, but I've only got about 3 maybe 4 threads showing as compared to the ones showing in the pic for the rear. My front bolts don't look like that picture at all.... I have actual head hex bolts threaded into those locations... I couldn't find any nuts. The head of the bolt if facing up toward the top of the wheel well if that helps paint a picture. I'll try to grab a pic tonight after work and post it.
Can you help me out some on these bushings you're talking about? Pictures of what they look like and where they're located in relation to the spring? Sorry guys, kind of hard to know what something is SUPPOSED to look like when you've never seen it the right way to begin with...
Thanks!!
Old Aug 24, 2011 | 08:38 AM
Six862m6's Avatar
Six862m6
Ah He!! I just looked at the first link that Mike posted yesterday... it shows some of the bushings a little ways down. I'll have to revist the front again but I don't have ANY bushings on the rear!! I'll check again this evening with pics in hand but I'm pretty sure not. Any idea of a good source to buy some factory bushings?
To Stock ride height
