Transmission fluid temp! What's the normal range?
Old Apr 27, 2002 | 10:57 PM
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
Default Transmission fluid temp! What's the normal range?
After monitoring my transmission temp., I seem to be running anywhere between 180* and 212* depending on what type of driving I'm doing. Is this normal or is it significantly out of normal range?
Only mods are vortex intake and PRT exhaust.
Old Apr 28, 2002 | 02:27 AM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Default Re: Transmission fluid temp! What's the normal range? (DAVS Y2K)
Dont worry..your fine.....if your seeing 220+, then I would be concerned...a forum member burned 3rd gear, and he was at 230 degrees... Mine runs about the same as yours...high 190's to low 200's
[Modified by y2k02c5, 1:27 AM 4/28/2002]
Old Apr 28, 2002 | 03:45 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Sounds like you are right in the ball park!
Old Apr 28, 2002 | 10:29 AM
carpe dm's Avatar
carpe dm
Sounds OK; in normal driving it will be pretty close to the water temp. :)
Old Apr 28, 2002 | 10:45 AM
Richin Chicago's Avatar
Richin Chicago
FWIW I have never seen a C5 automatic that doesn't display an high temperature fluid alarm after hards laps at Gingerman, on a warm day.
Old Apr 28, 2002 | 11:30 AM
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
Default Re: Transmission fluid temp! What's the normal range? (Richin Chicago)
Thanks for the replies and info. guys. I just had the third gear clutch pack and drum housing replaced in my a4 because it went out and was a little bit paranoid. I went on the Skyline Dr. cruise with the Southeast folks this weekend and after a hard run up a really great road with lots of curves the trans. fluid temp. rose to 216* and all I could think of was "not again!" :yesnod: :cheers:
Old Apr 28, 2002 | 02:02 PM
davette's Avatar
davette
Up to about 225 is alright for normal operating temps. If you are worried about your trans temps, just install a tranny cooler. About $40. Easy to install. I never see over 200 degrees since I installed my cooler, even with spirited driving. Normal cruising temp is about 185.
Good luck.
Old Apr 28, 2002 | 03:26 PM
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
Default Re: Transmission fluid temp! What's the normal range? (davette)
davette,
Did you install the trans. cooler yourself? Where did you get it and if you installed it yourself, is it much of a pain in the butt?
To Transmission fluid temp! What's the normal range?
