[HELP] AutoTap Guru's -->
Old Apr 27, 2002 | 11:57 PM
97C5ENVY's Avatar
97C5ENVY
Default [HELP] AutoTap Guru's -->
What's the difference between these two parameters: "Current Misfire Cylinder#" and "Misfire History Cylinder #"? I assume the "Current Misfire Cylinder#" parameter displays CURRENT number of misfires (ie. just occured), while "Misfire History Cylinder #" parameter displays a running total of number of misfires......True?....... False? Please educate me! Thanks!
Old Apr 28, 2002 | 01:51 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Default Re: [HELP] AutoTap Guru's --> (97C5ENVY)
I believe you are correct. 'Current' is just the last ~200 cylinder firings, 'history' is an accumulator updated at the same rate.
Old Apr 28, 2002 | 02:17 PM
intel55's Avatar
intel55
Yup you are correct. You will see the current go back to zero (or at least changing) after X number of rotations, while the history keeps an going total.
To [HELP] AutoTap Guru's -->
