Headlight pops up and drops
Old Aug 10, 2011 | 01:56 AM
shockwaveAZ's Avatar
shockwaveAZ
Default Headlight pops up and drops
Well after searching around I dint really find anything that help out. Both headlights pop up. But the passenger side once getting to the full open position and drops back closed. I turn the lights off and the passenger side pops back up and closes properly. now, i can open it manually to any position and it will stay open. The only time it wont is when i open it all the way to about where it would lock and it drops back down. WTF Im checking the connections, plugs and grounds first, but has anyone had this problem and know a solution?
Old Aug 10, 2011 | 07:27 AM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
Just an idea but maybe you have a bad headlight control module located on the firewall behind the passenger headlight motor.
While I didn't have the exact symptoms your have I did experience where one headlight would work fine while the other would work maybe halfway.
This was after I did the rebuild of both headlight motors with the brass gears.
I bought a used one from a vendor on the forum from a 2004 model year and it has lasted for quite sometime now without issue.
Old Aug 10, 2011 | 07:13 PM
shockwaveAZ
Some more info on whats going on. Was messing around with the headlight and I can hear a squealing/grinding noise coming from it. So Im thinking it the gear inside that is stripped maybe. Pulling it apart tonight to look. Also it only drops half way when i turn the lights on and off. So I dont think its the module.
Old Aug 10, 2011 | 09:35 PM
oh1vette's Avatar
oh1vette
squealing/grinding noise usually means gear...
good luck...
Old Aug 11, 2011 | 01:53 AM
Chicago1's Avatar
Chicago1
There are hundreds of threads on this so not sure how you didnt find it. Your gear is going bad you need a new one by a brass one and be done simple fix. Just did mine same issue.
Old Aug 11, 2011 | 02:09 AM
shockwaveAZ
Its all good. I used the search bar and must of just used the wrong words or I didn't think the thread really had what I had needed. It wasn't till i heard the grinding and all that did I feel the threads were what I needed.O well, brass GEAR HERE I COME
Old Aug 11, 2011 | 01:50 PM
Chicago1's Avatar
Chicago1
Same with the the how to thread on how to do it if you need some link let me know I have a few of the important ones. What's happening is you lost your some of the teeth on the nylon. It will happen to the other eventually.
Old Aug 11, 2011 | 11:49 PM
02koolC5's Avatar
02koolC5
First link is for the gears and the second link is the fix..hope that helps
https://secure15.prohosting.com/~a00...fddd4cd8df6d56
http://forums.corvetteforum.com/c5-g...post1562077756
Old Aug 12, 2011 | 01:48 AM
shockwaveAZ
yup, I ordered the parts this morning and cant wait to have a headlight that works right again
Old Aug 14, 2011 | 02:40 PM
Ricko's hav'n fun's Avatar
Ricko's hav'n fun
3rd Gear
Default pop ups
I have a problem with the drivers side light poppin up about an inch after the both close. Hope to find a fix, looks stupid.
Old Aug 14, 2011 | 04:05 PM
Chicago1's Avatar
Chicago1
lol did you read this thread?
Old Aug 14, 2011 | 04:18 PM
shockwaveAZ
The fix is here and you can even do it yourself look at you headlight gear
Old Aug 17, 2011 | 03:08 AM
shockwaveAZ
well I got the part in and pulled the motor. turns out the noise was coming from the gear that was not greased well. On top of that I already have metal gears inside looking around I found that the little stopping tab that the headlight arm hits was ripped up on the side it hits. This caused it to jump over and fall half way down. Anyway, I greased the gear and pulled the tab. I epoxied it and put it back on. WORKS LIKE A CHARM NOW So I'll have a gear kit for sale soon lol make sure you check your stopping tabs people lol
Old Aug 18, 2011 | 11:02 AM
Ricko's hav'n fun
3rd Gear
Default head light popping up after closing
I'm new to Covetter Forum and didn't see the thread you are refering to. They all seem to be discussing light dropping after opening, not coming up correctly or making noise. My problem is when the lights turn off they both close but the drivers side pops back up about 1 1/2 inch. Is that the gear?
Old Aug 18, 2011 | 12:07 PM
Chicago1's Avatar
Chicago1
It will be either the gear o like the OP found, the tabs chewed up. Just take the side covers out and see if they are chewed up. If the motor is making noise then it's the gear. Hope that helps good luck. PS I am a big smart *** read some of my other post it's not just you so don't get offended sunshine.
Old Aug 19, 2011 | 11:03 AM
Ricko's hav'n fun
3rd Gear
Will do what you said and check the gear. Hopefully that's it. There's not a noise problem. Will let you know what I find. Not offended at all!
Where do I get the brass gears?
Last edited by Ricko's hav'n fun; Aug 19, 2011 at 11:04 AM. Reason: want to add more
Old Aug 19, 2011 | 12:47 PM
Chicago1's Avatar
Chicago1
I got mine from Top down solutions I believe but just do a title search for "brass gear". They are about 50 shipped.
Old Aug 19, 2011 | 02:01 PM
AngryTurtle's Avatar
AngryTurtle
Maybe it learned a new dance move? Is it pop locking and dropping?
To Headlight pops up and drops
