steering connector voltage or resistance...
Old Aug 10, 2011 | 12:42 PM
alshirey's Avatar
alshirey
Default steering connector voltage or resistance...
Would anyone know about the connector under the car that's fastened to a power steering line on the steering rack? I am having an issue and asked to do a visual check. It appears fine but most of it is in black flexible tubing. I'd like to use a volt/ohm meter and get an actual reading. Without power is there some resistance that should be read and would that be from the male or female end? If the key is in, is there some voltage I should be reading and would that be from the male or female end? Please advise.
Old Aug 11, 2011 | 09:34 AM
alshirey's Avatar
alshirey
Bump.
Old Aug 12, 2011 | 12:39 PM
alshirey's Avatar
alshirey
ttt
To steering connector voltage or resistance...
