Need help with Speed Inc fuel rail install....
Old Aug 10, 2011 | 03:05 PM
FLYNAVY30's Avatar
FLYNAVY30
Default Need help with Speed Inc fuel rail install....
So I ordered a set of Speed Inc's aftermarket fuel rails along with the hose/fittings kit to hook them up to the factory fuel line/system. My only problem is that I now have a box full of very nice billet fuel rails, braided fuel line, and a plethora of fittings, but no instructions. Now I realize this isnt that complicated, and could probably be figured out in an afternoon, but I was hoping that anyone with some experience installing any aftermarket fuel rails could help me out with some tips, or at least a direction in which to start. Perhaps Ill take some pics and post a write up for others to use after I get this all sorted out. Thanks for any and all help!!
Old Aug 10, 2011 | 03:56 PM
zeevette's Avatar
zeevette
Is this to fit on an LS6 mani, or FAST? If stock, did the kit come with pedestals to connect to the mani? When you remove the stock rail, the mounts are all connected, as you well know. If they didn't send pedestals, maybe that's where you're confused? GL, Dave, I may be wrong, but on a basically stock motor, this mod is largely cosmetic, no?
Old Aug 10, 2011 | 04:37 PM
FLYNAVY30's Avatar
FLYNAVY30
Thats correct...this is purely cosmetic....Ive also deleted the AIR system, relocated the coil packs, and installed aftermarket valve covers. The LS is actually starting to look like a SBC after all.
These are for an LSX intake and did come with the pedestals. Ive got everything mocked up on my dining room table, I think the big problem is that with the fuel line entering the aft driver's side fuel rail, I dont think there's going to be enough clearance under the cowl to stuff everything back there. Im going to have to mess with it for a bit as I am pretty opposed to cutting the cowl
Old Aug 10, 2011 | 05:03 PM
FLYNAVY30's Avatar
FLYNAVY30
is there any reason why the fuel has to enter the fuel lines on the driver's side?? Ive actually got enough room to run the fuel line along the firewall, behind the intake to the back side of the passenger side fuel rail.
Old Aug 10, 2011 | 05:20 PM
lucky131969's Avatar
lucky131969
Same rules apply to a jet and a car. You don't want fuel lines rubbing, even if they are stainless. Make sure there is adequate room for the line to move freely. If I remember correctly, my friend had to have his Speed Inc fuel rails machined, so he could run the fuel line to the rear of the rails.
Old Aug 10, 2011 | 05:45 PM
zeevette's Avatar
zeevette
I agree. If possible, adapt the fittings to approximate the same area as stock, for the fuel line hookup. Also, there's a blocker plate on the stock rail for safety reasons, and it should have been removed, leaving room for the rear of the driver's side.
Old Aug 10, 2011 | 06:35 PM
WKMCD's Avatar
WKMCD
I think you may have problems on the drivers side. I had to cut the firewall to get mine in. I run a return style so the fuel has to go in the back.
Are you asking about how to cut the stainless hose and install the AN fittings? There are a bunch of videos on the web.
Old Aug 10, 2011 | 07:19 PM
FLYNAVY30's Avatar
FLYNAVY30
No I youtubed a video on how to cut and install the AN fitting. I was curious if there's any downside to running the fuel line to the back of the passenger side rail as opposed to the driver's side rail? Like you said, even with that plate removed on the driver's side, theres just barely enough room for the rail....no room for the 180 degree AN fitting needed to connect it to the factory fuel line.
Because Ive removed the AIR system, and the AIR tube that ran behind the intake, I have sufficient room back there to run the fuel line, secure out of the way so as not to rub on the intake) across the fire wall and into the driver's side rail. I just want to make sure that will in no way affect fuel flow to the motor.
Old Aug 10, 2011 | 08:10 PM
FLYNAVY30's Avatar
FLYNAVY30
Default New problem
Please excuse the low quality pic.....but Ive started to test fit everything, and notice that the driver's side sits about an inch farther aft than the passenger side rail. Anybody know if there's a specific driver's and passenger's side rail? Possibly they sent me two of one side?? I know I have the mounts on properly because theres only one possibly way for them to go on.
Old Aug 10, 2011 | 08:31 PM
lucky131969
Yep. Works out well for the seller, because they only stock one type of rail....which of course....fits both sides. This is what I was referring to.....in post #5.
http://forums.corvetteforum.com/c5-p...rails-red.html
Old Aug 10, 2011 | 08:37 PM
FLYNAVY30's Avatar
FLYNAVY30
Well thats just dumb. Besides looking stupid, you'd think that they'd have the driver's side rail being farther forward to allow for more clearance to get the fuel line in on the back side of that rail......not at all impressed with this set up.
Old Aug 10, 2011 | 09:07 PM
Rob Petyo's Avatar
Rob Petyo
Does this help at all?
Old Aug 10, 2011 | 09:30 PM
WKMCD's Avatar
WKMCD
The rails are the same. Having done mine, I don't se anyway to run the rail and AN fitting on the back of the rail without "clearancing" the fire wall. There's nothing behind there and it doesn't open it up to the interior.
Old Aug 10, 2011 | 10:05 PM
FLYNAVY30's Avatar
FLYNAVY30
it does....thank you! Looks like the FAST rails sit exactly the same as the Speed INC units
Old Aug 10, 2011 | 10:07 PM
FLYNAVY30's Avatar
FLYNAVY30
agreed....Ill mess with it some more tomorrow. Any chance you could post a pic of your engine bay?? I know you've sent me one before, but I lost it when my old computer went belly up. Thanks!
Old Aug 10, 2011 | 10:10 PM
lucky131969
So instead of having the fuel rail machined down, you cut the firewall?
Old Aug 10, 2011 | 10:15 PM
FLYNAVY30's Avatar
FLYNAVY30
I think he was talking more about the fiberglass cowl than the actual firewall. I think Im going to work on coming up with a safe way to run the fuel line to the passenger side....They send me more than enough line...plus I think that will make everything look a bit neater in the engine bay as well
To Need help with Speed Inc fuel rail install....
Old Aug 10, 2011 | 11:00 PM
Rob Petyo's Avatar
Rob Petyo
if you want to call the plastic/fiberglass behind the intake a firewall, yes I did it too, it's not like I'm ever going to put it all back to stock
Old Aug 10, 2011 | 11:14 PM
vsocks1's Avatar
vsocks1
Here is a picture to help hopefully....
Old Aug 10, 2011 | 11:30 PM
FLYNAVY30's Avatar
FLYNAVY30
thanks!!
