Picked up a TSP Cam, Cam Help
Old Aug 10, 2011 | 05:40 PM
BLKWDWZ06's Avatar
BLKWDWZ06
Default Picked up a TSP Cam, Cam Help
Picked up a cam from a friend on the cheap. Its specs are TSP Torquer V3 Int Duration 281 Duration @ .050 231 Valve Lift .644, Exh Duration 283 Duration @ .050 234 Valve Lift .598, Lobe Separation 111. Is this an aggressive cam or mild. What parts do I need to order to have this cam installed by a shop.
Thanks in advance!
Old Aug 10, 2011 | 06:18 PM
warren s's Avatar
warren s
Thats a fairly aggressive mid to top end power cam. Its going to be a bit limited by stock heads.
Depending on how many miles you have on your car, I would replace the following:
Valve springs (specific to handle that kind of lift)
Lifters (LS7)
Timing chain (LS2)
Oil pump
Old Aug 10, 2011 | 06:38 PM
Silnus's Avatar
Silnus
Torquer V3 is a nice proven cam and should be easier to tune than others because of its popularity so thats a plus. Its not exactly aggressive, but it is a very healthy cam.
Old Aug 10, 2011 | 09:45 PM
BLKWDWZ06's Avatar
BLKWDWZ06
thanks guys
Old Aug 11, 2011 | 07:48 AM
Paul 75 L82's Avatar
Paul 75 L82
Call Jon at Texas Speed, those guys are great and they can make a package with just what you need. That is a kick *** cam by the way.
Old Aug 11, 2011 | 08:36 AM
sfc rick's Avatar
sfc rick
Old Aug 11, 2011 | 09:28 AM
BLKWDWZ06's Avatar
BLKWDWZ06
Sounds like a plan, Thanks a million!
Old Aug 11, 2011 | 11:44 AM
DANZGLASS's Avatar
DANZGLASS
This is a mid sized cam with crazy lift. Makes great power but be ready to change springs every 15-20k miles. Must run strong valvesprings with these!
Old Aug 11, 2011 | 05:06 PM
chassed's Avatar
chassed
This man speaks the truth.. I had a much smaller cam in my car... After 20k miles a spring gave out and ruined the entire engine....
Old Aug 11, 2011 | 05:21 PM
ZZ06's Avatar
ZZ06
what springs were you running??....Did it just GIVE out? Or was there driver error
Old Aug 11, 2011 | 09:49 PM
BLKWDWZ06's Avatar
BLKWDWZ06
i called a shop and they said pack double springs for 675 lift would hold no problem, is this incorrect
Old Aug 11, 2011 | 10:52 PM
LSOHOLIC's Avatar
LSOHOLIC
I ran that cam with PRC .675's and Ti retainer $375. Full bolt ons (long tubes, xpipe, no cats, ZO6 Ti exhaust, 160 tstat, ud pulley and Vararam) it made 441/411 iirc.
This was on a '04 ZO6...not sure what your putting it in. Ran it for three summer and not a single problem. Idle was about 850 and it thumped. For a cam only setup it sure suprised a lot of people.
Thanks....FYI, check the base circle....iirc 7.450 was my push rod length.
Old Aug 11, 2011 | 11:09 PM
BLKWDWZ06's Avatar
BLKWDWZ06
Thanks for the great info, I have a 04, same mods minus 160 tstat and ud pulley....so prc's may be the way to go, gonna ring Texas Speed tomorrow. I have a Fast 90 im going to add, so looking for a LS2 TB to hook on to it. Wonder how much itll bring to the table with those mods.
Old Aug 12, 2011 | 12:34 AM
DANZGLASS's Avatar
DANZGLASS
yes those springs are plenty!. 441/411 with a v3 cam only? I want to hit that dyno! I only made 10 more with a set of milled and ported tfs220's heads and a ported 92/92 on a 228-232 cam. I would expect the 430whp range with that cam and the fast maybe a little more.
Old Aug 12, 2011 | 12:37 AM
BLKWDWZ06's Avatar
BLKWDWZ06
danzglass, will this setup keep pace with a c6z?
Old Aug 12, 2011 | 12:49 AM
DANZGLASS's Avatar
DANZGLASS
I would say no. They just have to much torque. At lower speed yes and at the track maybe if your a better driver. But the higher the speed gets the worse it will be for you. My tuner Charlie says I should be able to take a stock one. But an intake and a tune and they would get me.
Old Aug 12, 2011 | 12:50 AM
DANZGLASS's Avatar
DANZGLASS
You might want to think about a clutch and some injectors as well. You will be close to maxing the stock ones out.
To Picked up a TSP Cam, Cam Help
Old Aug 12, 2011 | 01:33 AM
ZZ06's Avatar
ZZ06
Yea with that kinda lift i would agree. I have a 233/239 and im at 92% duty cycle at WOT.
Old Aug 12, 2011 | 01:48 AM
BLKWDWZ06's Avatar
BLKWDWZ06
clutch and injectors on the list
Old Aug 12, 2011 | 01:52 AM
BLKWDWZ06's Avatar
BLKWDWZ06
might as well do heads too, then any recommendations
