Just Had the Rings Changed
Old Apr 28, 2002 | 07:32 PM
Andy_A's Avatar
Andy_A
Default Just Had the Rings Changed
I just had the #2 piston rings changed due to "higher than normal oil comsumption" problem. Is there any break-in period I should adhere to.
[Modified by Andy_A, 5:33 PM 4/28/2002]
Old Apr 28, 2002 | 10:13 PM
BLUTHUNDER's Avatar
BLUTHUNDER
Default Re: Just Had the Rings Changed (Andy_A)
Andy , whats the mileage on your C5 ?? What dealer did you take your car to ?
I/m consdiering getting my rings replaced also..I'm burning a QT every 800 Miles ;(
Jeff
Old Apr 29, 2002 | 02:28 AM
molon labe's Avatar
molon labe
i had it done a few months back. i have heard different things about breakin - anything from 500mi to 3000mi.
anyway, my oil consumption problems are now a thing of the past. :) i was burning a qt every 600-800mi before.
Old Apr 29, 2002 | 08:08 AM
Andy_A's Avatar
Andy_A
Default Re: Just Had the Rings Changed (BLUTHUNDER)
Had the rings done at Danvers Chevrolet, Danvers MA. I am friendly with tech that is very experienced. He did a fantastic job.
Old Apr 29, 2002 | 10:43 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
If the recommended break-in period for a new engine is 500 miles, I can't see how the break-in for rings would be any more than that.
Of course, I took it easy on mine for the first 500, then gradually turned up the heat until I did my first WOT-to-redline at 1,000. My car runs great but so do most of the ones that got used hard from the beginning.
Old Apr 29, 2002 | 10:54 AM
don527's Avatar
don527
I just had the #2 piston rings changed due to "higher than normal oil comsumption" problem. Is there any break-in period I should adhere to. [Modified by Andy_A, 5:33 PM 4/28/2002]
http://forums.corvetteforum.com/zerothread?id=283946
Old Apr 29, 2002 | 11:13 AM
molon labe's Avatar
molon labe
Default Re: Just Had the Rings Changed (Gearhead Jim)
thats exactly what i wound up doing. 500 mi real easy, and then gradually turned it up till i hit 1000mi, at which point i wound it out to 6200rpm and 150mph. :D
btw, when i asked the service tech about breakin, he didn't seem to know for sure. i suggested 2500mi, and he said "uhh ... yeah, that's it! yeah, yeah, that's it! uh huh! yeah!" so i don't listen to him any more. heck, i don't even take my car there any more since i found Adam @ Russell Automotive. :)
To Just Had the Rings Changed
