walbro 255 lph
Old Aug 11, 2011 | 01:07 PM
kj217's Avatar
kj217
Default walbro 255 lph
i am going to build a blwon 383,,
will the walbro GSS340 (255LPH) support this setup?
if not,, what are the alternatives?
Old Aug 11, 2011 | 01:39 PM
zeevette's Avatar
zeevette
First of all, ask the experts in the FI/Nitrous section. IMO, you'll need alot more than that pump, at the very least, a good BAP, and probably the Racetronic wiring harness.
Old Aug 11, 2011 | 02:19 PM
chevylad's Avatar
chevylad
I think that's what's in the A+A kit. I would have to go look at my kit to be sure. After that you can add a BAP or go to a dual walbro setup. It's depends on how much boost you want to run.
Old Aug 11, 2011 | 02:21 PM
kj217's Avatar
kj217
am going 13psi with meth injection,,
Old Aug 11, 2011 | 03:00 PM
sean.b's Avatar
sean.b
thats a popular pump in the aftermarket scene, but you're talking about FI on a lot of cubes (relatively speaking). i'd be leery of using that alone, but im not speaking from any FI on smallblock experience, i'll admit. just what ive done with 4 cylinders, and even with 4 cylinders ive seen that single pump exhausted on the more intense setups.
Old Aug 11, 2011 | 06:52 PM
SLEEPERFRC's Avatar
SLEEPERFRC
stock pump takes a **** at 500hp, Racetronix.com the hot wire kit 255 pump works up to 700
Old Aug 11, 2011 | 07:06 PM
kj217's Avatar
kj217
can i only buy the hotwire and use it with walbro GSS340 (255LPH)?
Old Aug 11, 2011 | 08:12 PM
SLEEPERFRC's Avatar
SLEEPERFRC
not sure the kit comes complete cost less than 400$
sell the one u got, an go with them or a boost a pump
Old Aug 11, 2011 | 08:29 PM
LoneStarFRC's Avatar
LoneStarFRC
Racetronix RFPK-007 fuel pump/hot-wire kit + BAP = Good to go.
Racetronix uses the Walbro GRJ420 255LPH pump in their kit. $277.99 if you buy direct. Then choose either a KB or MSD BAP.
Old Aug 11, 2011 | 08:51 PM
WKMCD's Avatar
WKMCD
I run the Ractronics kit with the Walbro 255 at 577RW and it handles it fine.
Old Aug 12, 2011 | 09:38 AM
kj217's Avatar
kj217
what about aeromotive stealth 340?
Deatschwerks DW300?
Old Aug 12, 2011 | 03:01 PM
LoneStarFRC
Deatschwerks DW300?
Aeromotive 340 will not fit C5s from '97 - early '04 models. It works in top-loading tanks only. Late '03 - '04 C5s and C6s.
I can't speak to the Deatchwerks stuff, but I don't think they offer anything for the '97 - E'03 C5s, at least not a drop-in replacement.
The inlet and outlet configuration on the C5 is unique and just because someone sells a submersible fuel pump dos not mean it will fit or work inside the fuel bucket in the tank.
Old Aug 12, 2011 | 03:18 PM
kj217's Avatar
kj217
what do you think of this from Andy?
http://www.aacorvette.com/supercharg...products_id=65
$1100k is a big turn off,,
Old Aug 12, 2011 | 03:33 PM
LoneStarFRC
Umm, yeah I guess it would be for most people too, but you didn't mention anything about your budget.
Old Aug 12, 2011 | 03:44 PM
kj217's Avatar
kj217
do i have to state the obvious?
below 500 unless necessary,,
Old Aug 12, 2011 | 03:59 PM
LoneStarFRC
For $500 (~) you can solve your problem but again, a lot will depend on how much total boost you're going to try to run and what you realistically estimate your flywheel horsepower will be.
They guys in the FI/Nitrous might give you some real-world feedback on their particular setups.
Old Aug 13, 2011 | 08:42 AM
kj217's Avatar
kj217
how to make sure my 99 C5 is a return-less?
To walbro 255 lph
Old Aug 13, 2011 | 09:59 AM
LoneStarFRC
Only one line coming off the fuel rail, correct?
Old Sep 5, 2011 | 04:43 PM
kj217's Avatar
kj217
who sells it for the same price beside racetronix?
Old Sep 5, 2011 | 05:02 PM
LoneStarFRC
Racetronix is the actual manufacturer of everything they sell, except the Walbro pumps themselves of course. They are in Canada and as far as I'm concerned, are the gold-standard for quality and innovation overall.
They do have some distributors such as Texas Speed, Thunder Racing, and some others.
