1993 stock motor and exhaust. first test failed all 3 (HC, CO, NO). Found out the head gaskets were bad pulling coolant through the exhaust.
Retseted and failed all 3 again but betteer than the first try.
Can it be the exhaust system is so dirty? Autozone did a check with a tool that he said all it showed was code 12. Something to do with the ignition module.
