Having some issues with my C5
Old Aug 13, 2011 | 04:22 PM
LaredoZ28's Avatar
LaredoZ28
Default Having some issues with my C5
Like the title says I'm having a few issues with my car. Of course I get the occasional misfire code due to my cam and it being untuned. The codes I don't understand are the following
B0333
B0361
B2606
B0441
I know the first 2 are AC but I dont know what they refer to. the third one is for A6 which i'm sure is the VATS system and I'm clueless on the last one. I'd really like to get the AC issue fixed due to me living in south texas and its hot as hell down here. I've already purchased a new HVAC control since my display isnt working.
I've also noticed that my wipers dont work and my hazard lights dont work in the back yet the turn signals do.
All help is appreciated.
Old Aug 13, 2011 | 05:52 PM
ICUALL's Avatar
ICUALL
B0333 indicates a problem with the outside air temp located on the passenger side front of the car.
B0361 indicates a problem with the Left Hand actuator blend door.
B2606 indicates a problem with the Seat vertical position sensor output to the seat control module
B0441 indicates a issue with left hand actuator position signal in the HVAC systerm
None of the codes listed should affect engine performance
Old Aug 13, 2011 | 05:57 PM
LaredoZ28's Avatar
LaredoZ28
would you be able to discribe or have pics of the outside air temp?
I read that B0361 and B0441 are issues with the actuator on the drivers side next to the radio so I followed all procedures to correct that issue. I believe I have that issue fixed (codes not coming back).
I greatly appreciate the help. I'm sure these are these are dumb questions. I'm just really new to the Corvette world.
Old Aug 13, 2011 | 06:07 PM
ICUALL's Avatar
ICUALL
Default B0330
B0333 The sensor is located on the right hand side of the engine compartment on the radiator support near the horn assembly. Make sure it is there and plugged in.
Old Aug 13, 2011 | 06:12 PM
ICUALL's Avatar
ICUALL
Default B0361 / b0441
http://vette.tnreeds.com/actuator/actuator.htm
Old Aug 13, 2011 | 06:22 PM
LaredoZ28's Avatar
LaredoZ28
Ok so I found the Sensor and made sure it was plugged in. I pulled it apart and the connections are rusted. I cleaned them with Electronics parts cleaner I have for Circut boards and Stuff at work then put it back together. It still doesnt work so I'm guessing I need a new sensor.
Old Aug 13, 2011 | 06:23 PM
LaredoZ28's Avatar
LaredoZ28
Yes thats the Thread I used to fix my actuator. Great thread and its looking like my hot/cold issue is fixed.
Old Aug 13, 2011 | 09:55 PM
ICUALL's Avatar
ICUALL
I recently replaced the ambient air temperature sensor on my 1999 C5 coupe. It is very easy. The part number is 10248414 (list $11.94). I purchased the part at my local Chevrolet dealer. The part bag was labeled, "Made in China (mainland)". I'm not sure if this part qualifies my Corvette to remain "An American Revolution!"
Raise the right front of the car (use a jack stand......). Remove the black plastic close-out panel under the car on the passenger side. It is attached with 5 or 6 small hex-head screws.
Use a small flat blade to push the "plastic nail" fastener up from underneath the car - the nail holds the sensor to the shroud. The sensor is attached to the right side of the radiator shroud, and protrudes through a small slit in the plastic. It will be obvious when you look at the sensor from underneath. It is difficult to reach inside and pull out the plastic nail connector - easier to push out from underneath.
Reach inside the close-out panel cavity and withdraw the harness that connects to the sensor. Remove the sensor - but examine the connector for corrosion. My original sensor connectors were corroded, but the connector was not (GM sells a replacement pigtail connector for about $32 list). My car is never driven in rain or snow, but the sensor was corroded. I'm not sure why - it has a weatherpack connector.
I used some silicone dielectric grease (GM part #12345579 - small tube and lists for $13.32) inside the sensor before plugging it into the connector - to prevent future corrosion.
Transfer the plastic nail to the new sensor, reach inside the close-out opening and insert the sensor through the hole. Push the plastic nail through the hole and then replace the close out panel.
It sounds complicated - but it isn't and should only take 5-10 minutes to change.
Good luck.
Old Aug 13, 2011 | 10:06 PM
LaredoZ28's Avatar
LaredoZ28
Good luck.
I found it earlier. I can get to it from under the hood. I'll pick one up monday from my local dealer and get the rest of the codes cleared up on the HVAC system.
I greatly appreciate the help. I know i'll me needing more help as soon as i get more codes.
Old Aug 13, 2011 | 10:18 PM
ICUALL's Avatar
ICUALL
Glad you located it, be sure you do a good job of cleaning the connector before you install the new one.....
Old Aug 13, 2011 | 10:30 PM
LaredoZ28's Avatar
LaredoZ28
That I deffinatly will. Next Time I'm in CC I'll hit you up.
To Having some issues with my C5
