The Engine Swap Begins!
Old Aug 13, 2011 | 10:51 PM
HardcoreABN's Avatar
HardcoreABN
Default The Engine Swap Begins!
So, yesterday I began the engine swap. The factory LS1 is going away and a 402 LS2 is going in it's place.
As it turns out, the previous owner had the stock LS1 heads CNC ported by a shop unknown to me, and installed a what appears to be a Comp Cams XFI™ RPM XR269HR. The odd thing is that for those parts, the performance wasn't there....
New engine specs:
- 402 LS2 Texas Speed & Performance short block
- Callies Compstar crank/rods
- Weisco pistons
- ARP 2000 rod bolts
- ARP main studs
- ARP head studs
- LG G5X3 114 lobe camshaft
- billet timing chain kit
- Siemens 60# injectors
- Edelbrock Victor water pump
- Melling high volume oil pump
- ARP 12pt SS engine bolt kit
- PFADT engine mounts
- MSD spark plug wires
- Comp Cams billet tensioner pulley
- LS2 style PCV system
- CNC ported LS1 Heads (simply because they should flow more than my LS6 heads) with Ti retainers/locks
- approx 11:1 compression
Future upgrades:
- AFR 230cc V2 or TFS GenX 230cc heads
- FAST 102 intake
- NW 102 Throttle body
- roller rockers
- Aeromotive fuel rails
- Aeromotive fuel pump/fuel pressure regulator
- oil cooler
- complete braided stainless line conversion
DAY 1 PROGRESS:
All that is left to pull the engine is to lower the cradle a little then it's out. Tons of cleaning required as I had a leaky nose/head gasket/valve cover lol.
DAY 2 PROGRESS:
Engine is out, in the process of stripping the parts off that I am reusing. **** my life is pulling the engine out from the top a pain in the dick. Never will I do that again. Had to pretty much drop the front cradle completely out of the car so the oil pan and damper would clear.
Once I get all the parts off, then a TON of cleanup begins. So far I am only a 1/2 day behind schedule.
DAY 3 PROGRESS:
So far, I have used close to a gallon of degreaser on all the parts I will be reusing, and still have to degrease the engine bay- mainly the engine cradle and spring. I scraped about 1/4" of crusty oil/crud from the cradle and spring already. I am NOT looking forward to hosing it off inside the garage but I am not putting the cradle back in and such just to push it out to do it, then to take it apart again.
Everything is mostly clean with the extra parts listed on CF and craigs list. Unfortunately, I do not have the timing chain damper (didn't know the LS2 had one) or a new pilot bearing so the only thing I will really be able to do tomorrow is finish up cleaning and change the trans/diff fluid.
DAY 4 PROGRESS:
Today I will be changing the fluids in the transmission and differential. Will have to wait to do the power steering and brake fluid. Will also finish cleanup and do any other prep on the new engine I can as I wait for the timing chain damper and pilot bearing to get here.
20 July Update:
Today I should finish assembly of the new engine and make headway on dropping it in and expect to have it completed by Sunday night. Monday I will pick up the few sensors I will be replacing and then the only thing left will be to have it flatbedded to a shop and have it tuned- I'm not even sure it will idle with the factory tune much less be able to drive it 40+ miles to the tuner. Right now the only 2 contenders in my search for a shop is Mayhem and RPM, with RPM currently in the lead due to being closer lol.
7 August Update:
Today hopefully will be the final day of the swap. Spent about an hour scrubbing the cradle and such to get all the oil off that the front seal decided to throw everywhere. Now there is a big puddle of nasty water in the garage haha. I will also be relocating the oil pressure sending unit to the front left oil galley passage- the silver plug behind the alternator. There was some modification needed to the right engine mount bracket to clear a threaded boss on the block. The modification does not look overly pretty, but I did not have the proper tools to do it right. I will be buying a new mount bracket and having the notch cut with a plasma cutter. The notch will also be smaller. I have fabricated an engine oil primer to use before the initial crank. More to follow on that and I am willing to make more and package them if there is any interest (the factory system is $300+)
13 Aug Update:
So having the engine fight me for 5 hours last weekend, I pulled it back out and re-aligned the clutch. After another hour or so I got it bolted up to the bellhousing. From there, the front cradle went on, the starter, valley cover, and started running wires for the relocated knock sensors and crankshaft position sensor. While relocating the knock sensors, I discovered that the engine mount brackets needed to ground down a little bit for them to clear. Not a big deal, a Dremel took care of it with the engine in the car. I also spent about an hour straightening the fins on the power steering cooler, that was fun. The starter has to come back off because I forgot to put the cover plates on first lol oh well it can be done tomorrow.
14 Aug Update:
Almost ready to fire it up and see if it will at least idle with the stock tune. Ran into some issues today. Found out the flywheel inspection cover somehow warped, the place I was going to relocate the oil pressure sending unit and prime the engine is a TERRIBLE place. While priming the engine with a pump thru the top oil galley plug (where the oil pressure sending unit goes), the pressure hose came off the pump and sprayed oil EVERYWHERE and now I get to spend a lot of time cleaning it up tomorrow. Also had to convert the PCV system to the LS2 style with a little modification. Instead of taking in fresh air thru the hose on the right valve cover, I put a vented oil cap on instead. All that is left to do is to put on the valve covers, intake/throttle body, exhaust, air intake, full the cooling system and flush/bleed the brake/power steering systems. I should be able to knock that out tomorrow after work so it can be towed to RPM motorsports in Garner, NC to get tuned. My vacation starting 18 Aug and a trip to WI is coming awfully fast....
15 Aug Update
It's alive! Well, sort of. Won't idle for ****, but will run with the gas pedal pushed down some. The location I selected for the Left knock sensor is NOT a good location if running LG long tube headers- the plug is about 1/8" off the header. I will have to get a LS2 knock sensor and move it near the oil filter. Wasn't able to bleed the power steering, cooling system, or check for leaks because it won't idle. Tomorrow I will put the rest of the exhaust on- OMG was it loud running open headers hahaha. Wed morning it gets towed to RPM Motorsports in Garner, NC to get tuned. Then Thurs/Fri I set off for WI. Not the best timing, but I grossly underestimated the time it would take to do this swap. I also need to buy 2 rear O2 sensors so I can get rid of the sims.
17 Aug Update
It has been towed to RPM Motorsports, and will be tuned by Friday, soooo nervous it's crazy. I can't help but be paranoid and think it is going to either grenade itself or dump oil everywhere. Will it? no, but the anxiety issues are kicking in lol....
18 Aug Update
While waiting for the car to be tuned at the shop, and since it is the first day of my vacation, think I will clean the garage. OMG is it nasty haha! Here is my list of things I still need to do:
- flush brake/power steering fluids
- change trans/diff fluid
- relocate L knock sensor
- replace front 2 O2 sensors and install rear 2 O2 sensors
- clean the bottom of the engine cradle
- replace both ground straps on the front spindles
- replace spark plug wires
- give a final cleaning to the engine bay
- replace some exhaust clamps and re-align the exhaust tips
Old Aug 13, 2011 | 11:07 PM
LaredoZ28's Avatar
LaredoZ28
looks really good.
Old Aug 13, 2011 | 11:16 PM
Dream C5's Avatar
Dream C5
Nice
Old Aug 14, 2011 | 12:18 PM
mowpow's Avatar
mowpow
Default Awesome! What year?
That looks awesome, great job. What year is your vette?
Old Aug 14, 2011 | 01:12 PM
HardcoreABN
'00 that I bought the day after I closed on my house in '06
Old Aug 14, 2011 | 01:31 PM
HardcoreABN
Now if someone could please tell me HOW THE HELL A FLYWHEEL INSPECTION COVER WARPS I would really appreciate it lol
Old Aug 14, 2011 | 10:45 PM
HardcoreABN
updated for today's progress
Old Aug 14, 2011 | 11:37 PM
TriplBlk's Avatar
TriplBlk
Nice job man. I'm somewhat surprised you went with TSP's 402 instead of the LQ9 408 for the money that is. I'll remember that the oil sensor was a bad place. Good luck ith the build man
Old Aug 15, 2011 | 09:23 PM
HardcoreABN
Updated for today's progress.
I wanted the AL block so the extra $500ish was worth it for the 100lbs I saved.
Old Aug 16, 2011 | 07:18 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Elbow For Knock Sensor
I used an elbow for the L/S knock sensor. I have it pointed towards the front of the motor. It cleared the mount and the headers.
Bob K.
Old Aug 16, 2011 | 08:31 AM
Quick Draw's Avatar
Quick Draw
Thanks for sharing with some of us who are not as mechanically gifted as your are.....and do not have the stones to tackle a project like this.
But most of all thank you for your service!
God bless and protect you.
Old Aug 16, 2011 | 10:50 AM
cdkcorvette7's Avatar
cdkcorvette7
Old Aug 21, 2011 | 10:14 AM
HardcoreABN
Looks like it will now be tuned on Monday, anyone wanna guess what the numbers will be?
Old Aug 21, 2011 | 01:00 PM
Dream C5's Avatar
Dream C5
450 RWHP, 415 RWTQ
Old Sep 11, 2011 | 01:05 PM
mowpow's Avatar
mowpow
Did you get numbers? Getting my 402 this week so just curious.
Old Sep 11, 2011 | 03:05 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Updates?
Old Sep 12, 2011 | 10:53 AM
waddisme's Avatar
waddisme
Been there done this! I wish I would have found this thread, I could have save you some headache with the knock sensor issue. You might want to do the oil cooler now. Getting that bracket on with headers is a big time b*tch! I have had mine in for 3 yrs now, driving the crap out of it for 20+ track days - still going strong! You won't feel complete though until you do the heads! Good luck with it.
Post us up some numbers when you get them.
To The Engine Swap Begins!
Old Sep 12, 2011 | 02:33 PM
sabastian458's Avatar
sabastian458
I remeber doing my swap. I ran into the same thing as you with the engine bracket and block, but I took out the mounting boss on the block. My knock sensor wires got a covering in reflective heat tape, completely covering the connector too.
I would have recomended upgrading the ground and power wires on the car when doing the engine too.
Old Sep 12, 2011 | 03:49 PM
mariofromnewyork's Avatar
mariofromnewyork
Late Model Domestics
Nice!
When you come up To the Beach lets do mine!
Old Sep 13, 2011 | 10:52 AM
chevylad's Avatar
chevylad
I like the way the painted block looks. I thought about it, but now I see how it looks and I regret not doing it.
