C5 radiator fitting size?
Old Aug 15, 2011 | 09:53 AM
caeierdam's Avatar
caeierdam
Default C5 radiator fitting size?
Sprung a leak in the radiator yesterday. Went to the parts house and they're asking me if my radiator has the 3/8" inverted fittings or the quick connect fittings. any ideas?? its an 02 automatic coupe..
Old Aug 15, 2011 | 10:02 AM
kris6868's Avatar
kris6868
I believe remembering 3/8" inverted for some reason when i got mine..
One of the other guys will chime in an confirm for sure...
Old Aug 15, 2011 | 12:25 PM
caeierdam's Avatar
caeierdam
Didnt think getting a replacement would be this hard. According to vin number im supposed to have a quick connect fitting but I just removed radiator and unscrewed the two trans cooler lines. I assume this means I dont have the quick connect fittings..dealer says i should have the quick connect and should change it out. anyone have a pic of the quick connect fitting just to make sure Im not an idiot and actually have this type
Old Aug 19, 2011 | 08:57 PM
caeierdam's Avatar
caeierdam
What a nightmare. apparently no radiator trans cooler inlets (3/8) match my hose size(5/8) and I was told by the dealer the 2 trans cooler lines are discontinued and Ill need to have some new hoses made up on my own. after a long day I just decided to have my old radiator rebuilt ($85) since the inlet sizes are correct....now just have to return the new radiator.
To C5 radiator fitting size?
