I have a 2003, C5, and the A/C control in the dash did not display the outside temp or the temp that the A/C was set upon when changed. I removed the display and soldered the 8 #241 resistors as advised on Corvette Forum. I also had to add a wire from the plugin since it was broken.
All resoldered items show that they are okay when tested with my meter. When I reinstall the display, everything works, however, the display, and the orange colored bulbs for the A/C, inside air, outside air, front and rear defroster, all blink every three seconds.
What have I missed? I don't know what else to do at this point.
