Performance axle
Old Aug 15, 2011 | 10:07 PM
Bits&Bytes's Avatar
Bits&Bytes
Default Performance axle
Back in 2002 I had a vert with z51 and performance axle (auto). A couple of months ago I bought a 97 coupe and it just doesn't seem to have the spunk/quickness as the 2002 vert.
How much of an issue is it to change to the performance axle from the stock one - Does the brain box need to be reprogrammed? Taken to a auto shop is it a major job (3 hrs? 5 hrs?).
Are the gears I'm looking for 3.42?
Tks, B&B
Old Aug 16, 2011 | 11:31 AM
rebelheart's Avatar
rebelheart
If you are going to go through the trouble,I would get the 3.42's over the 3.15's you had in your vert.Same cost,more seat of the pants performance!
Old Aug 16, 2011 | 12:09 PM
cdkcorvette7's Avatar
cdkcorvette7
The stock performance axle ratio is 3.15. that you may as well do 3.42s if you're going to do it. It'll feel like you have an extra 50 horsepower over the 2.73s you have in there now.
I don't know how many hours a shop will bill you for doing this but it'll be a little pricey as you have to drop the rear cradle. It's not too bad a job to do yourself if you have the ability and the tools. Here's a writeup that'll show you what you're up against http://forums.corvetteforum.com/c5-g...on-photos.html
No reprogramming necessary but you might want to have the speedometer re-calibrated to account for the larger gearing. A diablo predator handheld tuner can do this for you. It will also allow you to reprogram the shift points and firmness on your auto which will really wake it up. Look for one in the for sale section on here...
Old Aug 16, 2011 | 07:24 PM
craig04c5's Avatar
craig04c5
It is no more than a 5 hour job. If they know what they are doing 3.5 to 4 hours. I was with the tech when he did mine and it took him 4 hours but he let me clean the cradle up before putting it back together.
Old Aug 16, 2011 | 10:00 PM
SLVRCPE's Avatar
SLVRCPE
The speedometer output comes from the VSS which counts rotation of the ring gear. So, the new gears require the shift points to be corrected in an auto car.
I went from 2.73 to 3.42 and love them.
Old Aug 17, 2011 | 05:42 AM
Bits&Bytes's Avatar
Bits&Bytes
Tks all...
I think the next stop is new exhaust (stingers??) and new gears. I figure since I'm replacing the exhaust it would be a good time for the gears.
I'll have to post pics as soon as I can find the camera charger. Its a beautiful stock Nassau coupe, but it really needs a little more pep.
To Performance axle
