Serpentine Belt
Old Apr 29, 2002 | 09:22 AM
rozdesign's Avatar
rozdesign
Default Serpentine Belt
Going with the Goodyear...
Any tips on an easier or proper removal/installation procedure?
Also, how much tension (err.."play") should I allow in the new belt?
What's the normal wear, use time, on a serp belt? The service rep says I need a new one. Should I buy from the dealer or do it myself? Where do I get such a belt for the 5.7 V8, Pep Boys or similiar?
[Modified by rozdesign, 8:17 PM 5/16/2002]
Old Apr 29, 2002 | 09:29 AM
Scott97's Avatar
Scott97
Default Re: Serpentine Belt (rozdesign)
I've had 2 serpentines thus far.
I go to the track on a regular basis which probably has some bearing on belt life. ;)
You can get belts from Pep Boys Autozone etc.
Old Apr 29, 2002 | 02:14 PM
MikeV's Avatar
MikeV
Default Re: Serpentine Belt (Scott97)
Don't buy a cheap brand no mater where you buy it. Make sure it's Gates or
other name brand. Also, don't buy a goodyear Gator belt. They are noisy.
Mike
Old Apr 29, 2002 | 03:11 PM
lotzahp's Avatar
lotzahp
Default Re: Serpentine Belt (MikeV)
Gotta disagree on the "Goodyear belt is noisy" comment. I put one on because a new GM belt was squeaking just like the original. The Goodyear belt fixed the squeak and it is definitely not noisier than the OEM.
Old Apr 29, 2002 | 10:18 PM
CHJ In Virginia's Avatar
CHJ In Virginia
"Normal" wear time on a serpentine belt is very hard to gauge, and strictly dependent on type of usage. A visual inspection will tell you everything that you need to know about the belt. Are any edges frayed, any cracks on the smooth surface of the belt, any cracks side to side on the ribbed side of the belt ? If you have any of these conditions replace the belt, if not don't worry about replacement. Buy a good quality belt, they are only a few $ more and will repay you with much longer life. You can replace yourself in about 15 minutes, all it takes is a breaker bar or ratchet to take the tension off the spring roller.
Old Apr 29, 2002 | 11:15 PM
rozdesign's Avatar
rozdesign
Thanks all, questions answered well...Now what is a "good" quality belt if the Goodyear is not (don't know this yet) and where to purchase and for how much$$$?
Thanks again
Old Apr 29, 2002 | 11:30 PM
Untouchable00's Avatar
Untouchable00
Default Re: Serpentine Belt (CHJ In Virginia)
I like the gator belt, too. Great grip.
Old Apr 30, 2002 | 02:38 PM
lotzahp's Avatar
lotzahp
I bought my GY belt from a small parts store (not a chain, none of them in my area carried GY brand) for $29. I've listed the part numbers in another post if you want to search for it.
Old May 1, 2002 | 12:30 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
I got mine from NAPA :yesnod:
Old May 1, 2002 | 05:49 PM
LovintheC5's Avatar
LovintheC5
Default Re: Serpentine Belt (pkmoose)
I got a gates belt from autozone. Had to ask for a 97-98, as 99-up only came up with a part number for the a/c belt
Daren
Old May 1, 2002 | 07:00 PM
B. Stewart's Avatar
B. Stewart
Default Re: Serpentine Belt (LovintheC5)
Daren
You are right! Almost all of the parts houses don't have the large belt # even listed. Just the a/c. :mad
Old May 3, 2002 | 03:43 PM
JIM50's Avatar
JIM50
FOR 2001 SERPENTINE BELT-GATES BRAND KO6O798 -13.90
A/C BELT-KO40420 -9.60
DAYCO BRAND-5060800-23.45
A/C BELT-5040420- 9.35
THESE PRICES ARE FROM A PARTS STORE IN BROOKLYN, NEW YORK
Old May 3, 2002 | 03:48 PM
B. Stewart's Avatar
B. Stewart
Default Re: Serpentine Belt (JIM50)
When I bought the DAYCO it only lasted about a month! I don't know why because I understand that they make the o/e belts.
Old May 16, 2002 | 10:16 PM
rozdesign's Avatar
rozdesign
Old May 17, 2002 | 09:43 AM
lotzahp's Avatar
lotzahp
it's easy..........
15mm socket on the tensioner, push (standing on passenger side) and slip the belt off
then snake it through the other pulleys and discard
I recommend cleaning your pulley surfaces off while the belt is out (I used brake cleaner and a small wire brush)
Install new belt. I found it easiest to push most of the belt around the crank pulley, then situate it at alternator/pwr steer pump, then goto the pass. side and finish routing. Slip the belt over your socket THEN put the socket on the tensioner, then push the tensioner and slip belt onto tensioner pulley.
Double check that the belt is centered on ALL pulleys before starting it up.
Old May 17, 2002 | 11:47 AM
rozdesign's Avatar
rozdesign
Default Re: Serpentine Belt (lotzahp)
Thanks lotza!
To Serpentine Belt
