From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
New product for your C5 Corvette!
Hi Everyone,
Here is SacCityCorvette’s latest version of the Cool It v2 and v3 Remote High Speed Fan Controller for your 1997-2004 C5 and C5 Zo6.
Now you can control your C5 Corvette's radiator high speed cooling fan with the simple push of a button on your wireless FOB, allowing you to control your radiator coolant temps. No need to pay for a expensive tune to change your fans on/off temperatures or running you’re A/C to cool the engine, along with all the unnecessary wear and tear and fuel mileage loss that goes along with running the A/C.
The Cool It v2 and v3 now run on their own circuit and will not interfere with the normal computer controlled operation of your cooling fans.
Installing the Cool It v2 and v3 is a very simple five minute plug and play installation. (See our installation video) After you install the Cool It v2 or v3, you will be able to turn on the right side cooling fan on in high speed mode using a wireless FOB making it perfect for when you are at the track and you want to cool down between runs, in traffic and idling in parades. It will even help keep your Automatic Transmission running cooler too!
Originally Posted by ipuig
Turning on the A/C compressor starts both fans.
Hi ipuig
Yes it does turn the fans on. It also turns on the a/c compressor and the fan in the car. That's a lot of unnecessary wear and tear and fuel mileage loss that goes along with running the A/C just to cool the engine.
If you have a automatic C5, by keeping you coolant temps down will also keep your
transmission fluid cooler too, extending your fluid and transmission life.
So you won't have to service it as often. Helps make the Cool It pay for its self!
If you can lower your automatic transmissions fluid temperature you will not only extend the fluids life but your transmissions life.
And a cool transmission shifts better.
The Cool It v2/v3 will help keep your automatic transmission running cooler!
With a Cool It v2/v3 there is no need to run your A/C to cool the engine, along with all the unnecessary wear and tear and fuel mileage loss that goes along with running the A/C.
