"Circuit Insufficient Activity..."
So here's the deal, the car runs well for the most part. I occasionally have a dip in engine speed at idle, down to around 500-600 for a few seconds, then it comes right back up.
Anyway, every so often it will throw the CEL and codes P0140 Circuit Insufficient Activity Bank 1 Sensor 2, P0161 Heater Performance Bank 2 Sensor 2, and P1416 Secondary Air Injection System Bank 2.
I think I get that I have a problem with the air injection and I know it's not an uncommon problem, especially the check valve, but I'm a bit confused with the Bank 1/Bank 2 issue. Are banks 1 and 2 on the same circuit? I'm assuming banks 1 and 2 are left and right engine side. Am I wrong about that?
Anybody else run into this? Thoughts?
http://www.gearchatter.com/viewtopic9447.php
P0140 & P0161 are for the REAR 02 sensors--One for the driver's side and one for the pass side
Again here are the links from gearchatter to do diag. and repair
http://www.gearchatter.com/viewpost14541.php
http://www.gearchatter.com/viewtopic10710.php
Although the codes for the rear 02's are for different reasons--They still indicate that something is going on back there---
BACKGROUND----
ONLY the FRONT 02's are used for fueling your engine--They are the most important 02's--without them working your car goes into a power reduction "limp mode"
THE REAR 02's are ONLY used to report the "condition of your cats" period !!!
SO---these rear 02 codes can be telling you that:
1. both the sensors have failed and need replacement (cannot be cleaned)
2. The condition of your cats are BAD !! and need replacement
*really depends on how many miles your car has
*how well it's been maintained
oil change--religious injector cleaner--oil and fuel filters etc.
* constant use of bad gas
Combining the p1416 ( which is usually a carbon fouled check valve ( these can be cleaned sometimes) with the possibility of failed rear 02's or plugged cats-- to me points to a common sourse for all the codes---A carboned up dirty exhaust system.
Remember that the secondary air pump system pumps fresh Oxygen into your exhaust
Hope this helps---all of these are very Common codes even sometimes on well maintained cars--but cheap bad gas really fouls things up--I use my car traveling a lot and get gas from unknown stations and both my check valves failed and had to be replaced--
GEARCHATTER is the best DTC code and diagnostic site I've ever found--uses plain understandable language for repairs but also includes the technical stuff for those with test equipt.
I did this, and I've been OK since...
(Thanks to Bill Curlee for the post on this)
