pressure lose
Old Aug 21, 2011 | 09:50 PM
chicojon55's Avatar
chicojon55
1st Gear
Default pressure lose
# 8 cylinder is at 30 lbs. what can i do to get the pressure high without tearing the top of the moter apart.
Old Aug 21, 2011 | 10:36 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Are you talking about cranking compression test? If so, that's a dead cylinder that would need re-ringing, at the least.
Old Aug 22, 2011 | 12:47 AM
thetaxman's Avatar
thetaxman
surgery is required
there is no magic
Old Aug 22, 2011 | 07:17 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree. 30 psi is beyond any simple fix and the motor will have to come apart. You could pull the valve cover and look for a broken spring.
To pressure lose
