check engine light
Old Aug 22, 2011 | 01:12 PM
walleyejack's Avatar
walleyejack
Default check engine light
I know this topic as been , I put headers on last week,and have run it about 100 miles or so, now,yesterday the check engine light comes on,if I do the code procedure thing, I get lots of numbers and codes and things, that don t mean to much to me, do I have to write all the codes down then come back here somewhere and look each one up ? some have a c,some a h, some both. or just disconnect the battery for a few minutes and hook back up ?
Old Aug 22, 2011 | 01:43 PM
lucky131969's Avatar
lucky131969
Originally Posted by walleyejack
I know this topic as been , I put headers on last week,and have run it about 100 miles or so, now,yesterday the check engine light comes on,if I do the code procedure thing, I get lots of numbers and codes and things, that don t mean to much to me......
I assume this thread is soliciting the forum for help. There are a myriad of things that will precipitate a check engine light. If you don't post the specific codes, how can anyone help you?
Old Aug 22, 2011 | 01:44 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Long tube headrs are great !! however you will ALWAYS get codes---
Reason being the 02 bungs are further back then they were in the stock locations--This causes your ECM to get false 02 readings--also causes your 02's to not heat up correctly---also may cause your rear 02's to report false cat issues
Good news is that tuning can fix it all---These 02 related codes must be permanently deleted from your tune---A handheld tuner won't do--You'll need a full tuner like HP or EFILIVE--
PS: often times with LT's you may even make LESS HP until you get it tuned--as you won't get the full benefit of the LT's without one---That's why they are illegal in most states !!
Old Aug 22, 2011 | 01:46 PM
walleyejack
I can right the codes down and post them,I just didn t want to send 20 or so codes,but I can do that this evening, Thank you.
Al
Old Aug 22, 2011 | 01:49 PM
walleyejack
I am trying to get into a tune shop, I suspected that it had something to do with the headers,is running way rich. It probably took a few miles to cycle everythiing through the computer I m guessing.
thanks Al
Old Aug 22, 2011 | 02:10 PM
tlove32's Avatar
tlove32
Plain and simple - you need a tune. The CE light is due to the rear 02's being placed further downstream
Old Aug 22, 2011 | 02:44 PM
walleyejack
thats my thinking..
Old Aug 22, 2011 | 02:47 PM
walleyejack
thats my thinking..
Old Aug 23, 2011 | 01:31 PM
tblu92's Avatar
tblu92
thanks Al
Well sorta bad news---You will never correct the RICHER P/T closed loop AFR 100% ---LT's can make your PT fuel as rich as 14.0 to 14.5
AFR instead of the Stoich 14.68
But its really not that noticeable and not a big deal--
Noone knows 100% xactly how to correct the fuel back to 14.68--But I have had some good results by--
Lowering the 02 switching point table
installing the rear 02's onto the front location
leaning out the "commanded open loop table normal" ( for cold starting)
leaning out the VE table in the cruiseing RPM ranges
commanding a leaner closed loop fuel to trick the ECM
problem is that today's 02's have a very narrow band as to where they take accurate readings----That is around .450 millivolts or 14.68-1 AFR
Even if you try to command an AFR leaner like 14.98 to correct a 14.38 actual AFR ( wideband verified)
it beomes out of the " accurate" range of the narrowband 02
But if you are in a no smog roller state its OK--Again that's why LT's are illegal in many states as they dump more HC's into the air with a richer than needed AFR
To check engine light
