Column Lock- HELP NEEDED
Old Aug 22, 2011 | 05:07 PM
bdiddo's Avatar
bdiddo
Default Column Lock- HELP NEEDED
Developed the dreaded column lock when I started have "charging system fault" problem. i have read a ton of the info found here including the sticky which was very useful.
Now that i got the electrical problem resolved, the dealership says the lock motor is shot (vs. the ECL). Beofre taking it to them i changed out the connector to the alternator from the harness, the alternator, and three batteries. the drain would kill the battery is less than two days. i was able to "unlock" to steering wheel by using the method found here (pulling the #25) while i was still searching for the drain (which turned out to be connnector from the wire harness to the alternator) but now the steering column is locked again.
They said the part is around $200 plus 3 hrs labor, all said about $500+.
any ideas as to what is going on ? or should i have this part replaced?
Thx,
Old Aug 22, 2011 | 05:13 PM
mjoacim's Avatar
mjoacim
I don't know if it will help if the motor is possibly already bad, but mine started acting up and I installed the bypass kit that's $50 from Corvettes of Houston. You can order it online and call them as well to see if this kit will help your situation. I think there may be other kits available for a comparable price, too but Corvettes of Houston is a great source of knowledge. Hope this helps!!!!
Old Aug 22, 2011 | 05:19 PM
Chicago1's Avatar
Chicago1
Get a clb bypass from COH it comes with the clb and whatever it's called to unlock the motor. You should be gtg after that.
Old Aug 22, 2011 | 05:20 PM
mjoacim's Avatar
mjoacim
See, this guy knows what I'm talking about!!!
Old Aug 22, 2011 | 06:42 PM
bdiddo's Avatar
bdiddo
calling them now and thx!
Old Aug 22, 2011 | 07:02 PM
bdiddo's Avatar
bdiddo
just called COH and they said if the motor is shot it will need to replaced 1st. uhgg!!! I'll check the manual this evening to see if it is something i can tackle
Old Aug 22, 2011 | 07:22 PM
mjoacim's Avatar
mjoacim
Is the column locked as we speak?
Old Aug 22, 2011 | 07:23 PM
Chicago1's Avatar
Chicago1
The colum motor? I dought it but you never know.
Old Aug 22, 2011 | 07:30 PM
mjoacim's Avatar
mjoacim
If the column is locked right now, have you tried, taking the key out violently shaking the wheel, turning the key back on while shaking the wheel? I've had to do this MULTIPLE times before it would unlock, but it unlocked eventually every time.
Old Aug 22, 2011 | 10:20 PM
lucky131969's Avatar
lucky131969
You really have to be careful who you take advice from on this forum. 8VETTE7 is one of the good sources, follow his directions with confidence.
Old Aug 23, 2011 | 12:46 AM
shadowman1's Avatar
shadowman1
To Column Lock- HELP NEEDED
