Lost my locking wheel nut socket, now what ?
Old Aug 25, 2011 | 09:48 AM
DansVette's Avatar
DansVette
Default Lost my locking wheel nut socket, now what ?
Don't have the code as well. What can I do ?
Old Aug 25, 2011 | 09:50 AM
lucky131969's Avatar
lucky131969
Have you contacted the dealer? Perhaps they can look it up by VIN.
Old Aug 25, 2011 | 09:51 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
if they are from GM then SOME dealers have a master set but you will need to call around.
If not they sell a tool for removing rounded off bolts which would work or some tire places can do it without screwing up your car...
good luck
Old Aug 25, 2011 | 10:02 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
there is an old trick... buy a very cheap set of sockets, the cheaper the better.. find a socket that is slightly smaller than your lock nut..grinding out the lead in ( opening ... top of the socket ) to get it set squarely on the key nut.. then use a hammer to bang it on. make sure its a thin wall socket... once you hammer it on insert the 3/8th drive with your ratchet or breaker bar and it will come off.
Old Aug 25, 2011 | 10:34 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Most tire shops have the tools to remove wheel locks.
Old Aug 25, 2011 | 11:28 AM
chevylad's Avatar
chevylad
I've done this before and it works, but you have be careful not to scratch rims. This also means you are getting a new set or sets of locks.
Old Aug 25, 2011 | 12:30 PM
Blackjack888's Avatar
Blackjack888
Sears sells special sockets to remove the locks. Good luck.
Old Aug 25, 2011 | 12:33 PM
Baldfart's Avatar
Baldfart
I done this to my C4 when I had it. Worked Great!!!
Old Aug 25, 2011 | 01:27 PM
oh1vette's Avatar
oh1vette
If you wish to replace the original key you can try contacting Amcor Wheel Locks.
I sent them a pic of the lock pattern and they were able to match it and send me a replacement.
During my research at the time it was either a McGard or Amcor lock, tuned out to be Amcor on my 01.
Good Luck
Old Aug 25, 2011 | 03:12 PM
cdkcorvette7's Avatar
cdkcorvette7
This. It worked for me when I got my car and didn't get the lug key with it . I replaced the locks with a regular lug nut...
Old Aug 25, 2011 | 03:13 PM
CHJ In Virginia's Avatar
CHJ In Virginia
This trick works. I have found that if you use an IMPACT 6 Point socket, you can get the nuts off and not destroy the socket. A 6 point grabs the nut better and an impact socket will not break or split allowing multiple uses. Once the nut is off, place the socket on a vice and drive the nut out using a drift punch or something similar, it will be in the socket tight !
Old Aug 25, 2011 | 03:30 PM
DansVette's Avatar
DansVette
Thanks for the help guys. I'll try the 6 point impact socket first, and then go from there. I'll report back !
Old Aug 25, 2011 | 03:35 PM
lucky131969
Why wouldn't you try calling the dealer first? Either way, you need to have the socket
Old Aug 25, 2011 | 03:39 PM
jrose7004's Avatar
jrose7004
I lost the socket for some wheel locks I had on a camaro that I used to have and those locks didn't even slow them down at Pep Boys.
Old Aug 25, 2011 | 04:15 PM
oh1vette's Avatar
oh1vette
My concern was damaging the wheels during the "break off" action....
Old Aug 25, 2011 | 07:40 PM
Silnus's Avatar
Silnus
Had to do this on my GTO to all 4 tires. I broke 3 sockets, and a custom rim shop broke 7 others finally getting them all off and replacing with ordinary ones. Rim theft isnt very prominent these days, at least around here. I will not have locking lug nuts UNLESS I owned rims upwards of $3000.
Old Aug 25, 2011 | 09:40 PM
4DRUSH's Avatar
4DRUSH
I took a cold chisel & worked them loose, of course I destroyed them.
To Lost my locking wheel nut socket, now what ?
Old Aug 26, 2011 | 06:21 PM
DansVette's Avatar
DansVette
The 6-point impact socket worked like a charm. Took a 3/4" pounded it on, and it broke loose easily with a long handled ratchet. In fact, the whole procedure was so quick and easy that thieves must laugh when they see these kind of locking nuts on wheels.
My C4 had a different system that would probably be harder to defeat.
ANYWAY, THANKS A MILLION FOLKS FOR THE ADVICE !! THIS BOARD SAVED ME AGAIN !!
Old Aug 26, 2011 | 09:49 PM
Quick Draw's Avatar
Quick Draw
Now that you are aware that the locking lugnuts doesn't stop thieves, just do what GM did with the '04s. Use GM chrome lugnuts for the C5 without the cheap looking plastic covers.
I like the ones which came on my '04. No key to lose.
Old Aug 27, 2011 | 01:36 AM
9020v's Avatar
9020v
Get a 12 point impact socket that is just a little to small, get a sledge hammer, and hammer the thing for about 5 minutes until you get it on as far as it will go. Then put an impact wrench on it and blast it off.
Other option, if you're a really good welder, weld a smaller allen nut to it (if you can protect the wheels).
