Oil filter adapter
Old Aug 29, 2011 | 09:51 PM
98Camarod's Avatar
98Camarod
Default Oil filter adapter
I have an oil pan for my twin turbo'd motor and apparently it uses the pf48 oil filter. From what I've read, that's used for the dry sump applications. I don't have that. The oil pan is a fbody oil pan that was apparently converted to that. Does anyone know where to buy the swap or if running the pf48 will adversely affect me?
Old Aug 30, 2011 | 10:39 PM
jeanlucpicard's Avatar
jeanlucpicard
Well, my 2006 Honda Civic, 2001 C5 Vette and 2007 Z06 (dry sump) all use the same tiny-azz oil filter so I am not sure it really makes a difference. Your oil filter model is the over-priced GM version of the Fram filters I use. Screw it and rock on.
Old Aug 31, 2011 | 05:05 AM
98Camarod's Avatar
98Camarod
I found out that there is an adapter that can be purchased to replace the fill adapter on the current pan to use the original ls1 filters. So I bought that. It will be here tomorrow.
To Oil filter adapter
