How NOT to slam your C5!
Old Apr 30, 2002 | 12:27 PM
bparker's Avatar
bparker
Default How NOT to slam your C5!
After leaving the races this weekend - I pulled off @ a convienient store for a drink and to meet a buddy before heading back home in I20 (bout a 2 hour trip).
When leaving, I had just started to reverse out of the parking spot and the lower A-Arm nut came off the lower arm and the passenger side front end pretty much collapsed to the ground. Or in this case onto the wheel.
I will leave it to your imagination as to how lucky I was to have had this happen @ 1 MPH rather than 100+ on the interstate!! Would have been a disaster most likely..
You will see in some of the pics the lower a-arm and nut sitting inside the wheel..
Couldn’t have been more lucky...
Thank you God for watching over me!
A TON of friends and racers stopped and helped me out.. I had NO tools for repair and with all the help - we put her back togther and was on our way.
Yes - I did go ahead and check the driver side before we continued and it was just as tight as it could be.. :eek:
I would HIGHLY suggest that you guys either put on a second nut - or drill out the stud and put a cotter-pin through the hole to keep this from happening
Best Regards,
BP
http://myhost.virtualgiant.com/bparker/A-Arm1.JPG
http://myhost.virtualgiant.com/bparker/A-Arm2.JPG
http://myhost.virtualgiant.com/bparker/A-Arm3.JPG
http://myhost.virtualgiant.com/bparker/A-Arm4.JPG
Old Apr 30, 2002 | 12:31 PM
GR8-LIFE's Avatar
GR8-LIFE
Default Re: How NOT to slam your C5! (bparker)
WOW!!!! I could use luck like that to win the lottery!
Old Apr 30, 2002 | 12:41 PM
WildWolf's Avatar
WildWolf
Was your car's height 100% stock or did you lower it via stock bolts or aftermarket lowering kit? That must have scared the sh-t out of ya.
Old Apr 30, 2002 | 12:42 PM
see5's Avatar
see5
You were very unlucky to have that happen and stunningly lucky as to the circumstances. Looks like no collateral damage?
This is scary to think about! Has anyone else ever heard of this happening?
Old Apr 30, 2002 | 12:55 PM
bparker's Avatar
bparker
Default Re: How NOT to slam your C5! (WildWolf)
Sorry - I forgot to include this info..
I had lowered the car further about 3 weeks ago - by cutting the bushings in the front and using longer studs in the rear.
I did tighten both front studs down equally - and one fell off the other one was still tight.. know knows.. :confused:
Also - imagine this - I have been driving around for about 2 1/2 weeks like this and in several highspeed senarios since I re-loered the Z :eek:
Whatta mind trip!
Old Apr 30, 2002 | 12:57 PM
bparker's Avatar
bparker
Also, the inside of the wheel has about a 1 inch "gouge" - but you cant see it unless the wheel is off the car.. :jester
Old Apr 30, 2002 | 01:09 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
:eek: :eek: :eek: :eek: :eek:
Very glad that you (and your car) are OK. :cheers: This will definitely make me think twice about messing the the car suspension.
-Tuan
Old Apr 30, 2002 | 01:23 PM
Snowman's Avatar
Snowman
CI 1-2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '03-'04-'05-'06-'07-'08-'09
Wow! I looked at your pics. You WERE lucky.
Me too. About a month ago, I blew off my driver's side rear caliper and found the bolts were somewhat loose on all of them. It makes sense to go through our cars periodically checking EVERYTHING.
Also was tres cool that people stopped to help you. I had my friends Adman (Matthew) and Saxn8r (Corey) to help me limp along for 130 miles on almost no brakes to Dallas for repair.
Couldn't tell by the pics exactly but did you score the inside of the wheel?
Doug
Old Apr 30, 2002 | 01:30 PM
The One's Avatar
The One
:eek: You left a few minutes before me, Brent. Don't know how I missed you. I'm very happy you were able to fix it on the spot and that it didn't happen on I20. Take care, buddy. :blueangel:
JC
Old Apr 30, 2002 | 02:34 PM
RajunCajun2001's Avatar
RajunCajun2001
Man you were lucky. Glad to hear there were good people on the road that night to help you out. :cheers:
Old Apr 30, 2002 | 02:36 PM
Big Carrot's Avatar
Big Carrot
You just need to put a little juice on your car to make it feel better. How bout tonight???? :D :D :D
Old Apr 30, 2002 | 02:47 PM
bparker's Avatar
bparker
Default Re: How NOT to slam your C5! (Big Carrot)
HAHA - :yesnod: - I think tonight would be great!
Did ya move one already? let me know when you get finished!! :D
Old Apr 30, 2002 | 03:02 PM
wwashing's Avatar
wwashing
Whatta mind trip!
You must not have torqued that nut down. If you did and it backed off, it will do it again. Those nuts just don't unscrew themselves. If you are absolutely positive that you didn't forget to tighten that nut, then someone losened it for you. :eek:
[Modified by wwashing, 3:05 PM 4/30/2002]
Old Apr 30, 2002 | 03:08 PM
MySea6's Avatar
MySea6
I have heard of this once or twice before. Wish I knew what caused it.
Assuming each time the nut was torqued to spec? Both of mine have
been apart more than once but I check the nuts frequently now. No
problems here.
You are very fortunate. All I know to do is torque to spec. Maybe a real
Vette tech will jump in here and tell us what may be going on. :confused:
Old Apr 30, 2002 | 03:15 PM
AP's Avatar
AP
Default Re: How NOT to slam your C5! (MySea5)
Now thats low ... but seriously ... sorry for your accident...
Old Apr 30, 2002 | 03:32 PM
NoMercy's Avatar
NoMercy
Default Re: How NOT to slam your C5! (NewVetteLover)
YOINKS!! :eek: :eek:
That could have been really ugly!
You are a lucky man bro ... thanks for sharing. I bet there is at least one more person on this forum you may have just saved!! :cheers:
Old Apr 30, 2002 | 03:44 PM
bparker's Avatar
bparker
Default Re: How NOT to slam your C5! (wwashing)
oops - double clicked reply :jester
[Modified by bparker, 1:45 PM 4/30/2002]
To How NOT to slam your C5!
bparker's Avatar
bparker
Your guess is as good as mine - all I can say is that I tightened them as hard as I could. I am no small fella either..
In fact I had been joking with some friends about how the front end is only held together by a couple of bolts a few weeks ago after I lowered it.. so trust me I recognized the danger of not having it tight when I was putting everything back together.. but without using a torque wrench - I can not say how many lbs I had on the nut..
NoMercy, good point - hey I hope any of you whom read this that have lowered your cars to go check - it doesnt take that long and it could also save your rear end - and no not the cars rear end either! :D
Old Apr 30, 2002 | 04:03 PM
robsvette's Avatar
robsvette
bparker, you r blessed!!!
see5, dude, you have to lower that baby! looks 4X4 :eek:
Old Apr 30, 2002 | 05:52 PM
Big Carrot's Avatar
Big Carrot
Still waiting...... :sleep: :sleep: :sleep:
