ABS\Trac light code on friends C5-thoughts?
Old Aug 30, 2011 | 08:56 AM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
Default ABS\Trac light code on friends C5-thoughts?
I am working on fixing some gremlins on a friends 02 C5. It is throwing the dreaded bad relay code for the ABS\traction control. But here is my question. The car will not hold voltage. I am pretty sure the alternator is gone. I can charge the battery over night and then it goes dead after sitting for just 5 hours. Could the voltage problem be causing the ABS\traction control code? Thoughts please. I have done extensive research, but this theory just popped into my head. Thanks.
Old Aug 30, 2011 | 09:13 AM
dougbfresh's Avatar
dougbfresh
Originally Posted by meadowz06
I am working on fixing some gremlins on a friends 05 C5. It is throwing the dreaded bad relay code for the ABS\traction control. But here is my question. The car will not hold voltage. I am pretty sure the alternator is gone. I can charge the battery over night and then it goes dead after sitting for just 5 hours. Could the voltage problem be causing the ABS\traction control code? Thoughts please. I have done extensive research, but this theory just popped into my head. Thanks.
YES, low voltage can cause the diags on startup to fail. Fix the charging before he KILLS the battery, clear all codes via the DIC and see what happens.
Old Aug 30, 2011 | 11:26 AM
meadowz06's Avatar
meadowz06
I can't clear the abs/trac code. It won't clear. I checked all the ground connections and they are fine. It is throwing the bad relay code.
Thanks!
Old Aug 30, 2011 | 11:49 AM
dougbfresh's Avatar
dougbfresh
Thanks!
The 1214 code? AND, by the way-there was no 05 C5 Corvette!
Old Aug 30, 2011 | 12:21 PM
lucky131969's Avatar
lucky131969
No offense, but sounds like you need to get some facts straight.
1) As brought up.....no 05 C5....so is this a C5 or C6?
2) If the battery is charged overnight, and discharges within hours....the alternator is not the issue.
Old Aug 30, 2011 | 12:28 PM
meadowz06's Avatar
meadowz06
It was a typo! It's an 02! And it is the 1214 code!
Old Aug 30, 2011 | 12:30 PM
meadowz06's Avatar
meadowz06
Again, typo. If not the alternator, then what do you think is draining the battery?
Thanks!
Old Aug 30, 2011 | 12:58 PM
lucky131969
Thanks!
This is a common issue, and has been discussed for years on the forum. Bill Curlee has a very good write up, on auditing the current draw.
http://forums.corvetteforum.com/1567522286-post590.html
The C1214 is also common is you search.
http://forums.corvetteforum.com/c5-t...r-fleabay.html
Old Aug 30, 2011 | 01:39 PM
dougbfresh's Avatar
dougbfresh
1214 is an easy DIY fix if you can solder or you can send the EBCM out for repair. There is a thread on the repair if he/you want to attempt it-it's a $3 relay.
Old Aug 30, 2011 | 02:03 PM
meadowz06's Avatar
meadowz06
Thanks for the replies. I have searched the threads, but thought I might find something new.
Old Aug 30, 2011 | 04:28 PM
meadowz06's Avatar
meadowz06
Ttt
Old Aug 30, 2011 | 04:43 PM
dougbfresh's Avatar
dougbfresh
Ttt
What else do you want here?
Old Aug 30, 2011 | 05:38 PM
meadowz06's Avatar
meadowz06
A sarcastic comment! Thanks!
Old Aug 30, 2011 | 05:51 PM
lucky131969
Perhaps, but seriously..............what additional answers are you looking for, that have not been provided?
Old Aug 30, 2011 | 11:06 PM
02koolC5's Avatar
02koolC5
Those threads are what I used to fix my relay....bought relay at digikey.com for 1.78 and a desoldering iron at radio shack and went to town...good luck....my codes and dash light would not clear as well, and as far as the battery goes I'd get a new one
To ABS\Trac light code on friends C5-thoughts?
