Key Fob
Old Apr 30, 2002 | 03:00 PM
danwsm's Avatar
danwsm
Cruising
Default Key Fob
I have a 99 corvette, after the battery was disconnected the key fob stopped working. How do I get it to work again?
Old Apr 30, 2002 | 04:44 PM
VetteBiz's Avatar
VetteBiz
Default Re: Key Fob (danwsm)
Hey Danwsm,
I'm sure the forum members will reply with the exact procedure. But from what I remember when I performed it on my car you need to hold the lock and unlock button simultaneously on the key fob, near the car, for a couple of seconds.
I believe the procedure is outlined in the owners manual.
Biz
Old Apr 30, 2002 | 04:51 PM
Richin Chicago's Avatar
Richin Chicago
Default Re: Key Fob (VetteBiz)
Hey Danwsm,
Biz
You need to hold lock and unlock down, on the fob, for about 10 seconds. If you hear the horn honk you are back. If not there is a more extensive procedure in your owners manual which you do through your DIC (digital information center) and is a complete reprogram that will work for any fob including a new one.
Old May 4, 2002 | 09:43 PM
luvinc5's Avatar
luvinc5
Default Re: Key Fob (Richin Chicago)
After I changed the battery, I cannot get the fob to work consistently. Basically, the vette fails to recognize the fob after 12 hrs or so of no use. I have done both the quick relearn (holding the lock and unlock buttons for a few seconds) and doing a fob relearn thru the DIC. Does anybody have a solution?
To Key Fob
