Can't programs key FOB's
Old Sep 3, 2011 | 06:23 PM
NVR_L8's Avatar
NVR_L8
Default Can't programs key FOB's
I had several codes that are reoccurring in the BO-RFA Section C 2115 H (Left rear TPM Sensor Malfunction), U1016 H (Loss of Communication with PCM), U1064 H (Loss of Communication with BCM), U1096 H (Loss of Communication with IPC, and U1255 H C Serial Data Line Malfunction. I understand that an H after the code means history and C is current. When I clear the codes and try to reprogram the three key FOBS none of them are recognized again. The dash sits there at "Press the lock and unlock button on 1st fob" I will not learn. I will then recheck then codes and the same codes will come up.
Old Sep 3, 2011 | 06:30 PM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
is it possible the fobs need new batteries?
Old Sep 3, 2011 | 06:38 PM
NVR_L8's Avatar
NVR_L8
Default Key Fob
I replaced the batteries on all three remotes and still not even one key fob can be programed.
Old Sep 3, 2011 | 07:35 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Check the fuses. I don't know which one it is, but check all of them
To Can't programs key FOB's
