Air Inlet Screen / Wiper Cowl Replacement
Old Sep 4, 2011 | 08:45 PM
SG Lou's Avatar
SG Lou
Default Air Inlet Screen / Wiper Cowl Replacement
I'm getting a new one as mine split in two.
Is there a trick to removing the washer nozzles without breaking those off ?
Old Sep 6, 2011 | 12:01 AM
SG Lou's Avatar
SG Lou
NOBODY?
Old Sep 6, 2011 | 08:02 AM
craig04c5's Avatar
craig04c5
No trick, they just push out from the top to the underside. They are just held in with rubber grommets.
Old Sep 6, 2011 | 08:40 AM
lucky131969's Avatar
lucky131969
Originally Posted by SG Lou
NOBODY?
You deserve an answer dammit. Let's go people !
Old Sep 6, 2011 | 03:07 PM
SG Lou's Avatar
SG Lou
Thanks Craig
No big deal Lucky.....
Worse comes to worse I break one of them !
Old Sep 6, 2011 | 09:02 PM
craig04c5's Avatar
craig04c5
As an added note while I had no problem pushing mine out if you are concerned you could also spray some silicone spray on the rubber grommets to make them easier to slide out of the retaining hole on the wiper cowl. Mine is a 2004 and I replaced the OEM cowl with a Hydrocarbon cowl so the OEM rubber was still very pliable and easy to push out.
Old Sep 7, 2011 | 11:07 AM
SG Lou's Avatar
SG Lou
Mine is an 04 as well Craig. I'll try pusing out first. If they give me a hard time I'll give each one a shot of Silicone.
Thanks again for the tip !
Lou
Old Sep 7, 2011 | 01:40 PM
LoneStarFRC's Avatar
LoneStarFRC
Tip: Turn key on, turn wipers on, turn key off when wipers are in mid stroke, mark wiper position on glass with masking tape (lift blade, apply tape to glass, lower blade onto tape, mark position on tape with pen), remove wiper arms and continue replacement process.
To Air Inlet Screen / Wiper Cowl Replacement
