Hotchkis end link adjustment.
Old Apr 30, 2002 | 11:41 PM
turboo2u's Avatar
turboo2u
Default Hotchkis end link adjustment.
I'm looking to get a little less push with my Hotchkis setup. (more oversteer), so I lengthened the rear sway bar end links. You can unscrew them 21 times before they come apart. I unscrewed them 7 turns. I assume this makes the bar stiffer, and therefore will increase oversteer. Am I assuming correctly? :confused:
Old May 1, 2002 | 12:06 AM
davidfarmer's Avatar
davidfarmer
Default Re: Hotchkis end link adjustment. (turboo2u)
Length alone has nothing to do with it. The more parallel the bar's "arms" are to the lower control arm, the less resistant it will be. With the car on the ground, or the rear suspension otherwise settled (control arms on jackstands for instance) you should check the squareness of the bar.
Dave
Old May 1, 2002 | 12:34 AM
Gary2KC5's Avatar
Gary2KC5
Default Re: Hotchkis end link adjustment. (y2khardtop)
Dave,
excellent observation!! and thanks for keeping us in check! :yesnod:
Old May 1, 2002 | 03:15 AM
turboo2u's Avatar
turboo2u
Default Re: Hotchkis end link adjustment. (Gary2KC5)
The assumptions in the post was based on information from the folks at Hotchkis as well as Xtreme motorsports, so now I'm really confused!
To Hotchkis end link adjustment.
