F45 Select Ride Option
I couldn't tell any difference between the 3 settings, although they are supposed to change the ride stiffness for competition.
Changed to coilovers 3 yrs ago as I sometimes autocross the car and could not be happier with them.
Have heard others say they can't tell F45 setting diff either.
Also I've read that C5's with this option was shipped with protector blocks on the shocks that were supposed to be removed upon delivery, but some slipped through with the blocks still on and some cars were driven for thousands of miles like that. Maybe thats why some don't feel any difference in the settings. Just thinking outload here.
Does F45 actually work? I clearly can tell the difference between tour & sport, but only on some pretty crappy roads or bridges with poor transitions. It is subtle as Phil said, but detectable. The more the shocks wear, I'll bet you can't tell.
That being said, I've got a box of C6 Z06 shocks in a box just waiting like japc5. I probably wouldn't have paid $1000 for the option initially, but the original owner did. I'll spend the $10 to make simulators when the Z06 shocks go on rather than try and replace with other F45 shocks.
Todd
You used "cheap" and "the dealer" in the same post, but I don't think that is possible.
I've only seen 2 or 3 forum members replace F45's with the same. Almost everyone else opts to disable the F45 system and go aftermarket. F45 shock prices are at least 4X higher than C6Z06 ($250 for all 4).
Since you did say "cheap", switching it all out to non-F45 shocks is the only way, and the dealer probably won't do it for you. An alternative to simulators is to have the F45 "programmed out" of your car with a Tech-II, which the dealers have. You might luck out and find a dealer who will turn off F45 and install C6Z06 shocks for you.
F45 simulators can be made with four 10watt 10ohm resistors from Radio Shack, one for each wheel. Cut the harness of each shock and solder the resistor in-line.
You then have several options of non-F45 shocks like Bilsteins, or C6Z06. I usually recommend Gene at gmpartshouse.com. Helpful, easy txns, and he's been a supporter here for years.
Todd
I switched to F55 the newer system used in 2003+ cars. GM makes a conversion kit, it's expensive but you can definitely tell the difference.
I guess what bothers me is no noticeable difference in ride and the dial selector on the console has no 'click stops" for each setting. The dial turns freely from tour to performance.
Car is a 2002 with 95000 miles.The car handles ok but I am not experienced enough to tell if new shocks are needed.
Thanks Todd and everybody else who responed.
Jeff
Tour = 110 ohms, Sport = 290 ohms, Perf = 650 ohms.
My service manual calls for using a scan tool to measure voltage while in-use, but I think this route is easier for a DIY. I just measured mine above. If you get no variation between settings, the switch is busted internally.
I'm at 66k, and will probably change them due to age. Things like leakage, squeaking, or excessive bounce are definitive signals for change. I put just C6Z51 sway bars on early this year, and it behaves like a new car. Many report new shocks & sways do the same, but it's hard to tell how much is attributed to shocks alone.Todd K
Does anyone know how to get the service manual on DVD ?
Thanks Jeff
Todd
I notice a slightly softer ride in the tour mode cruising on the highway, than the performance mode cruising on the highway. Sport mode, I dont notice much.
Most of the time I keep it in tour unless I know im playing, then Ill click it to performance.
Highway cruising I keep it on tour because its a slightly softer ride.
Damn expensive to replace.
www.TampaTuning.com
