switch out the air conditioning climate control
Old Sep 11, 2011 | 10:38 PM
woody2b222's Avatar
woody2b222
5th Gear
Default switch out the air conditioning climate control
I would like to know the best way to remove and replace the H V A C climate control
Old Sep 11, 2011 | 11:05 PM
lucky131969's Avatar
lucky131969
Are you referring to the control head?
Old Sep 12, 2011 | 09:02 AM
dougbfresh's Avatar
dougbfresh
Remove surround, unbolt Head Unit, disconnect connections on rear.
Old Sep 12, 2011 | 11:47 AM
cdkcorvette7's Avatar
cdkcorvette7
Your post is a little vague; but if you're doing what I think you're doing:
Follow steps 1 - 3F on this link http://www.vetteessentials.com/instr...zel_howto.html
Then remove the two bolts (7mm I think) holding the AC Control Unit in place and it'll slide out. There's a wiring harness on the back you'll have to disconnect...
To switch out the air conditioning climate control
