Following an oil change, will the "oil life" sensor automatically re-set to 100%, or will the "Oil life" reading continue to decrease from its level immediately previous to the change even though the oil and filter have been changed?
That is, if prior to oil change the sensor reads 26%, following an oil change, will it read 100%, or will it remain at 26% and continue to decline with use?
Thanks!
It is not a sensor, it's software written into the PCM's programming.
