Rear end ratio
Old Sep 13, 2011 | 04:22 PM
NorthEnco's Avatar
NorthEnco
Default Rear end ratio
Pardon my ignorance but is there a way to determine the rear end ratio
through code numbers or something.
2002 C5 Automatic convertible.
Old Sep 13, 2011 | 05:02 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Assuming it's stock you will have either a 2.73 (std) or 3.15(performance) axle gear ratio. If you car is equipped with the performance axle, it will indicate option code RPO G92 in the service parts ID sticker located on the inner surface of the glove box door.
Old Sep 13, 2011 | 05:26 PM
NorthEnco's Avatar
NorthEnco
Default Thanks
This place is great, Thanks very much
Bob
Old Sep 13, 2011 | 05:28 PM
lucky131969's Avatar
lucky131969
......of course this only applies if the OP is the original owner, and knows without a doubt, that the rear end has not been changed/modified.
Old Sep 13, 2011 | 05:33 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Perhaps you should take the time to read the first three words in my post.
Old Sep 13, 2011 | 05:37 PM
lucky131969
I'm working on my post count. Thanks anyways.
Old Sep 13, 2011 | 05:54 PM
bmfrc's Avatar
bmfrc
Go drive 75 mph in 3rd gear, if you see 2700rpm, its a 273, 3100rpm, its a 315. I think...
To Rear end ratio
