1/4 Mile with a G-Tech..Is it relyable?
It is my only option since we don´t have any race tracks around here. :(
Is things like the G-Tech accurate?
Anyone tried it?
My results in the 1/4 mile are : 13,50 sec./109 mph.
0-60 mph : 5,18 sec.
I am a little disappointed with my 13,50, but it´s perhaps normal for a car with moderate mods like mine..??? :cry
The tires spun just a little so the act.handling did not activate.
So... I would really appreciate if somebody can look at my numbers and mods and say if it looks realistic or if there´s something wrong here... :blueangel:
But...are my car atleast an "average" fast C5 or should it be faster with my mods? :confused:
I have read on this forum that it can be a big difference between stock vettes, on dynos and in "real life"
I wonder if mine is one of the low-hp vettes.???
You mentioned that the tires spun a bit. The launch is the most important part of measuring acceleration and quarter mile
times. This little bit of spinning cost you at least a tenth or two right there.
Make sure that traction control is off. It will slow you down if it is on.
It takes lots of practice to get really good quarter mile times.
I have brought the G-tech with me to the drag strip on several different runs with all my cars. Here are my results!
1st with my Vette... A 99' Hardtop M6 with light mods..
The G-tech avg within 2 tenths of a sec. but was 5+ mph high every run.
for example.... G-tech said 12.48 at 118... actual was 12.62 at 112
Now with my Mustang it was off by more. Usually 4 tenths quicker and also 5+mph faster. For example.... G-tech said 11.88 at 122... actual was 12.21 at 116
With the Prowler it read quick too.. usually 4 tenths and 7+ mph
Ex.... G-tech 14.27 at 98...... actually 14.69 at 91
The girlfriends Trans Am Ram Air A4( stock!) was just 2-3 tenths but still 5+mph high.
Ex... G-tech 13.12 at 109... actual 13.39 at 104
There you have my research. In all cases it has generated quicker and faster times then were actually recorded at the track. For what it's worth I think it is amazing what it can do from just a plug in and stick on unit. The 0 to 60 times seem accurate to me... C5s best is 4.28.... to the Mustangs 3.98.... prowlers 6.02... T/As... 4.88
I wont tell you how many runs it took me to break the Mustang into the 3's! Lets just say way to many!
[Modified by C5 Frank, 6:23 PM 5/1/2002]
The G-Tech in our case is almost dead on with time and about 3-4 mph higher due to the way it measures final speed.
Great for testing mods and real impacts of changes.
:cheers:
Think about it this way: How much speed do you think the car will pick up in the last 66 feet? Consider that the car is traveling more than 160 ft/s at 110 MPH (a plausible speed at the traps). So to pick up 3 MPH in 66 feet, we're talking accelerations of about 10 mph/second. (This doesn't even mention the fact that you would have to gain more than 3 MPH to net a 3 MPH gap between the G-tech time and the average speeds recorded by the traps.)
I use a Race Logic AP-22. Out of the box, it reports .15-.3 seconds slower than the timeslip. But I can calibrate the unit with a correction factor. The main advantage, however, is the ability to download the acceleration data and create results like this:
In continuous recording mode, the AP-22 will record rollout data (which is lost or completely unaccounted for by the G-Tech). The car's rollout can take as much as .4 second. I am changing the correction factor and going back to the track in two weeks.
If anyone is interested, I will start a new topic that goes over the AP-22 functions.
[Modified by Racer281, 7:41 PM 5/1/2002]
The times in the graph were recorded this weekend. (And yes, I know I drove like an old lady. 12.9@112 with lots of wheel hop.) I will go back to get less embarassing times.
[Modified by Racer281, 7:40 PM 5/1/2002]
BTW, my G-tech gives pretty much the same data as earlier posts. If you can get good traction on the street, we have found it shows effects of mods pretty reliably. Like others, we do not take much trust in the speed. ET is pretty consistent with our local ¼ mile track.
I have seen this before now that I see the site. It will be interesting to see your comments on how it functions, what particular features do you use the most, etc. I like electronic gizmo’s, even more if they help you!
Now that I have run my 3500 rpm Vigilante :cheers: for the first time last night (no traction with run flats, as expected along with 90 degree weather!), I would like to learn more about the effect of the higher stall TC on the run.
Neil :flag
[Modified by cruzin', 9:35 AM 5/2/2002]
-Pete
higher trap speed though.I took mine to the strip and it was pefect as
far as the times go.
Highly recommended.
01GT
:cheers: :cheers:
