2004 shifter cable
Old Sep 14, 2011 | 07:54 PM
music4lin's Avatar
music4lin
Default 2004 shifter cable
Hey does anyone no the part number for the shift cable on an 04 ? Found 12561688 but it says it doesn't fit an 04....... Help with part number? Thanks in advance ..........
Old Sep 14, 2011 | 08:03 PM
lucky131969's Avatar
lucky131969
Who says it doesn't fit an 04? Was there a dramatic change between 02 and 04?
Old Sep 14, 2011 | 08:05 PM
music4lin's Avatar
music4lin
I don't know. Everything that I have found goes up to an 03....
Old Sep 14, 2011 | 08:11 PM
lucky131969
So this isn't necessarily true "Found 12561688 but it says it doesn't fit an 04"
So you think there was a change from 03-04?....doubtful.
Old Sep 14, 2011 | 08:19 PM
music4lin's Avatar
music4lin
I know...... Just don't know why every site I have been to tells me that 12561688 is for 97 - 03 ????????????????? Hate to order wrong part. I had to pay $ 100.00 tow bill to get the car home today. I sure don't want to order a part just to find when it gets here it's wrong.
Old Sep 14, 2011 | 08:35 PM
lucky131969
Then the safe bet is to call the dealer, right? ............or contact Gene at GMPartshouse.com
Old Sep 19, 2011 | 07:51 AM
music4lin's Avatar
music4lin
There is a different cable for the 04. Corvette Central list them both. Don't know what the difference is ????????
Old Sep 19, 2011 | 09:36 AM
1FUNC5's Avatar
1FUNC5
Call dealer... Give them last eight of your vin and they can match correct cable for YOUR car.
Old Sep 19, 2011 | 02:17 PM
music4lin's Avatar
music4lin
2004 shift cable part number 10352529. Took me long enough to find it. Some people don't like to give out the part number and I understand why. Thanks http://www.number1gmparts.com Don't know what the difference is but there is.
Old Sep 19, 2011 | 02:33 PM
lucky131969
Interesting.....
10352529 $78.19 $0.00 $49.93
Automatic transmission - Gear shift components - Gear shift control - Shift control cable
Shift control cable, corvette 2005
Old Sep 19, 2011 | 09:01 PM
music4lin's Avatar
music4lin
Well ..... ordered the part today. Thank you to number1gmparts.com for the correct part and info. Remember if you have an 04 and need a shifter cable you need part number 10352529.
Old Jan 30, 2020 | 04:37 PM
ChiliPepperGarage's Avatar
ChiliPepperGarage
Corvettes are Chevrolet's. They are not high end luxury automobiles and they were priced accordingly. Sounds like you got one that had some minor issues. The good news is like the original cost, fixing them is relatively inexpensive. Every price Porsche parts? Those cars are better built than Vette's but cost way more.
As far as the early cars, the C5 has way more content than C2's and early C3's. In order to save weight and cost, GM uses plastic (as do every car manufacturer) and other less costly materials. You can't compare a modern car to an older one and expect everything to be the same.
Old Jan 30, 2020 | 06:52 PM
UM Rebel's Avatar
UM Rebel
The front t mount is different on the 04. I have replaced cable on my 04 and a friend's 02.
Part number of 04 is 10352529. You probably find it for a reasonable price on eBay of Amazon.
It's a bit of PITA to install.
Old Feb 2, 2020 | 08:33 PM
bobgroger's Avatar
bobgroger
My benchmark for quality is rattles. My 33k mile C5 has none. My 100k Passat has none, and has needed NO work except recalls, oil changes, tires, and 1 set of brakes. Every 60's-70's car I ever owned had several annoying rattles. How did those C3 points work out? I will put up with most any mechanical ills but rattles? No. Oh, and GM, Ford, and Chrysler '80s peeling paint. Gone by the C5.
To 2004 shifter cable
