Active Handling Service Advice Needed
Old Sep 16, 2011 | 07:50 AM
carhopper's Avatar
carhopper
Default Active Handling Service Advice Needed
My newly purchased 2001 convertible has a service active handling system fault. I read the tutorial on this forum and it was very helpful, but I would like some advice on where to start with the codes I'm getting. I did check the ground connection point and it had already been thouroughly cleaned and dielectric grease applied. I also checked the connection to the module and it was nice and clean.
When I read the codes after the original fault I got the following historical codes
C1225H - Wheel Spin Variance
C1287H - Steering Sensor
C1288H - Steering Sensor
U1000H - Loss of communication undetermined
U1064H - Loss of communication with BCM
As I was driving on a trip this week, I actively checked the codes right after they happened and C1288 is the first one to appear without fail, then it was later followed by U1064. I haven't seen the wheel spin return yet.
The question is, since I'm getting the U1064, should I go after that as it seems more systemic or is that a result of the wheel spin sensor since it came second.
Old Sep 16, 2011 | 08:36 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Probably a bad steering wheel position sensor but need to ask if your wheel alignment is correct?
Old Sep 16, 2011 | 08:37 AM
carhopper's Avatar
carhopper
It's really close, but probably off by 1 degree or less.
Old Sep 16, 2011 | 09:22 AM
sjc*2's Avatar
sjc*2
I have had these codes as well for some time
Finally bit the bullet and replaced the SWPS. All codes have gone now. If you are reasonably good with tools then it can be done in your garage. I did my own and the instructions on the forum really help.
To Active Handling Service Advice Needed
