How do you remove the door panels?
Old May 1, 2002 | 09:23 PM
Rewind61's Avatar
Rewind61
Default How do you remove the door panels?
Did a search no luck.
Thanks in advance.
Robert
Old May 1, 2002 | 09:45 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: How do you remove the door panels? (Rewind61)
lemme see what I find for ya...I just did mine :D
Old May 1, 2002 | 09:47 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
posted the instructions in this thread:
http://forums.corvetteforum.com/zerothread?id=269731
Old May 1, 2002 | 09:49 PM
Oregonvette's Avatar
Oregonvette
Robert,
I replaced my door panels about a year ago with some Torch Red accented panels. From memory I think you first remove the bezel surrounding the latch that opens the door. It is the oval shaped piece. It just snaps on, so use a flat bladed tool like a paint scraper to get under the lip. Careful not to scratch, and then gently pull off. There are two torx screws underneath that need to come off. The panel that has the window switches can be gently pried up, don't scratch, and pulled out. The power plug can be pulled out and the switch panel set aside. Then the only thing left holding the panel on is a series of plastic pins that are attached to the panel along the bottom edge, five I think, that are pushed into holes in the metal door. The trick to getting the panel off from here is getting something between the panel and the door, along the bottom, so you can gently pull it out. I used a large screw driver and covered the blade with duct tape so it would'nt scratch the paint on the door to pry the panel out some. then I pulled the panel off pin by pin using my fingers once I could get them in the gap. Careful with what ever you use to pry, that you don't scratch. The panel pins pull straight out. It's a bit scary but once you do one, it gets easier. Just take your time and don't pry or pull real hard. Once all the pins pop out on the bottom, the panel lifts up to and out of the window channel. I hope I've remembered everything. Good luck.
Old May 1, 2002 | 10:02 PM
Rewind61's Avatar
Rewind61
Mean Green 2000, Oregonvette
Thank you both for the info. :)
I would hate to have to buy a new panel
because I didn't have a clue. :crazy:
Robert
Thanks for the super fast responses.
Old May 1, 2002 | 10:09 PM
corvcharles's Avatar
corvcharles
Funny, I was struggeling with the same thing just 2 days ago. This link even has the pictures to show you what you're looking for. http://www.momentsoflight.com/sunsetvette/mods_wc.html
Old May 1, 2002 | 10:41 PM
SteveL2's Avatar
SteveL2
I hope this should answer all your questions, and maybe get you thinking about Ken King and Vette Essentials at the same time: :D
Link-o: http://temp.corvetteforum.net/c5/ste...or_handle.html
Old May 1, 2002 | 11:28 PM
Rewind61's Avatar
Rewind61
Default Re: How do you remove the door panels? (SteveL2)
Thanks everybody with directions it was a piece of cake. :)
Robert
Old May 1, 2002 | 11:51 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
:cool: :cheers:
Old May 1, 2002 | 11:52 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: How do you remove the door panels? (Mean Green 2000)
whatcha up to btw :D
Old May 2, 2002 | 12:03 AM
Rewind61's Avatar
Rewind61
I added some insulation to fix vibrations and rattles
when I turn the stereo up. It's like a new stereo now.
Thanks to you guys :cheers: :D
Robert
To How do you remove the door panels?
