2284
The LH Door Control Module (LDCM) has two main power feeds (high and low), and one main ground. The low power feed (battery 1) is used to provide power for the LDCM logic and internal driver operation. The high power feed (battery 2) is used to provide power for systems that draw higher amounts of current (motors, lights etc.). For most functions, the LDCM will operate properly when vehicle system voltage is between 9.0-16.0 volts. The LDCM also monitors the voltage level at battery 1 and battery 2 circuits and can determine if the voltage level received is out of range. If the voltage level is out of range in either circuit , then a malfunction is present and a DTC will set. [/QUOTE]
Check your battery terminal connections to make sure they aren't corroded and are on nice and tight. Then check the wiring in the rubber accordion tube going to the left door. If those both check out okay take a look at your grounds: http://forums.corvetteforum.com/c5-t...tion-long.html
2284
Check your battery terminal connections to make sure they aren't corroded and are on nice and tight. Then check the wiring in the rubber accordion tube going to the left door. If those both check out okay take a look at your grounds: http://forums.corvetteforum.com/c5-t...tion-long.html[/QUOTE]
I tried the battery and the plugs.no help.
Tomorrow I'll start on the grounds but the diagram doesn't tell me exactly where they are.I assume the LDCM must have it's own ground
Thanks,John
Thanks,John[/QUOTE]
