p1870 code
Old Sep 19, 2011 | 09:55 PM
knapptime's Avatar
knapptime
Default p1870 code
i have 1998 corvette automatic. last summer i had the trans rebuilt and put in a ptc 2800 converter. tranny and converter has worked great. this year i installed a procharger at the beginning of summer. everything has been fine all summer. the other day i was driving it and the converter wasnt locking up after shifting into overdrive. now it has a
p1870 code. everything else with the tranny seems fine. anybody ever heard of this? thanks
Old Sep 20, 2011 | 10:11 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I found this:
This GM service bulletin might apply to your vehicle:
TSB # 01-07-30-023A
Harsh 1-2 Upshift, SES, MIL, or CEL Illuminated, DTC P1870 Set (Replace Valve Body)
1996 Buick Roadmaster
1996 Cadillac Fleetwood
1999-2000 Cadillac Escalade
1996-2000 Chevrolet Camaro, Corvette
1996-2000 Pontiac Firebird
1996-2000 Chevrolet and GMC Light Duty Truck Models
1996-2000 Oldsmobile Bravada
with 4L60-E Automatic Transmission (RPO M30)
Built Prior to January 15, 1999 (Julian Date 9015)
This bulletin is being revised to update the Parts Information.
Please discard Corporate Bulletin Number 01-07-30-023 (Section 07 -- Transmission/Transaxle).
Condition
Some customers may comment on a harsh 1-2 upshift and the Check Engine Light or Service Engine Soon indicator is illuminated.
Diagnosis
Typically, these vehicles will have been driven more than 32,000 km (20,000 mi) before this condition occurs.
The scan tool may show a DTC P1870 set as a history code.
A harsh 1-2 shift or DTC P1870, caused by wear in the control valve body, may be difficult to duplicate when the transmission temperature is below 93°C (200°F).
Cause
The condition may be due to wear in the control valve body. This wear occurs in the bore that contains the TCC isolator and regulator valves, and results in poor, or no, TCC apply.
Important
DTC P1870 is a type B code. The conditions for setting the P1870 DTC must occur on TWO CONSECUTIVE TRIPS (ignition cycles, with a drive cycle) before setting a P1870 history code.
When the conditions for setting DTC P1870 are met (first trip), the PCM commands maximum line pressure and harsh 1-2 shifts are the result.
This may result in a harsh 1-2 shift with no history code if the conditions for setting the DTC required for the second trip are not met, on two consecutive trips (Ignition cycles, with a drive cycle).
When the conditions for setting the DTC are met, on the second consecutive trip, a DTC P1870 is stored as a history code.
When the P1870 code is stored, the PCM will turn on the Service Engine Soon (SES), Check Engine Light (CEL), or Malfunction Indicator Lamp (MIL).
Correction
Install a control valve body with the revised TCC regulator and isolator valves. These valves are used in all transmissions produced after January 15, 1999 (Julian Date 9015), and all of the service parts currently available through GMSPO contain revised TCC regulator and isolator valves.
Important
If all of the following conditions are true, it is not necessary to rebuild the transmission or to replace additional transmission components beyond the control valve body.
Transmission operation is normal before the transmission reaches operating temperature, or before DTC P1870 is set (no slips, flares, or missing gears).
The torque converter is not blue or overheated.
The transmission fluid is not burned or has no burned odor.
The transmission fluid pan contains no abnormal debris (clutch material, bronze, brass, or metal fragments
Old Sep 20, 2011 | 09:05 PM
knapptime's Avatar
knapptime
thanks. i do not have a hard shift everything with the tranny seems fine until overdrive then the converter isn't locking up.
Old Sep 20, 2011 | 10:29 PM
soggysailor's Avatar
soggysailor
There is a reasonably cheap fix. You need the TCC valve rebuild kit. Ask at your trans shop or shops about it. I found one almost immediately that knew exactly the problem and how to fix mine. They did a full trans service and while the pan was off they pulled the valve body. Took less than 2 hrs for them to do all the work. Its been 4 years and no issues or codes. I had one shop that insisted I needed a complete trans overhaul
Old Jun 28, 2013 | 07:49 AM
CathieS627's Avatar
CathieS627
Navigator
Default Same problem
Any chance anyone knows where I can get the TCC Valve Rebuild Kit?
Old Feb 26, 2015 | 06:08 PM
Mipi47's Avatar
Mipi47
1st Gear
Default Have I must exchange valvebody????Must???
Originally Posted by dgrant3830
I found this:
TSB # 01-07-30-023A
Condition
Diagnosis
Cause
Important
Correction
Important
To p1870 code
