Reprogram Fans 03 Z06?
Old Sep 20, 2011 | 04:46 PM
bartsky's Avatar
bartsky
Default Reprogram Fans 03 Z06?
How do you reprogram fans to come on sooner on an 03 Z06? I have read many threads on here, and know when they come on stock. My car has a front splitter, and no factory air dam. Would this make it run warmer than usual? I guess I have to find someone with HP tuners? Do I have to change thermostat if I get them reprogrammed to come on sooner? Thanks...
Old Sep 20, 2011 | 04:57 PM
cdkcorvette7's Avatar
cdkcorvette7
Answers in Blue
You'll need tuning software or a device like a diablo predator. Several in the FS section here.
Almost definitely. Unless your front splitter directs air upwards and through your radiator as you drive like the factory air dam does...
You don't HAVE to but you should. One mod compliments the other.
Thanks...
Old Sep 20, 2011 | 05:10 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
You will have to have someone with HP Tuners or other tuning program change the on/off settings of the fans. You will have to pay for the license.
We have a simple option you might be interested in. Here's a link.
http://forums.corvetteforum.com/c5-g...-corvette.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Sep 21, 2011 | 09:07 AM
Blue Angel's Avatar
Blue Angel
You may want to clean out your radiator as well.
I have an '02 and have visually checked under the nose of the car to make sure there were no plastic bags or leaves clogging the rad many times, and never ever found antything.
I recently had my rad out of the car and HOLY CR@P, the rad was plugged SOLID in front of the fans! It was full of little bits of dust, dirt, and all kinds of other things that were wedged into the fins and could not be seen from below (even though you can see between the rad and AC condenser). I thought the rad was fine even though almost half of it was plugged up!
You can clean the rad by removing the shroud/fan assembly and spraying it with water from behind, then removing the front shroud (beneath the air cleaner) and spraying the AC condenser from the front (go back and forth, front to back, a few times to make sure anything that comes out of the front of the rad doesn't end up in the back of the condenser).
If you're going to replace the thermostat and will have the rad drained anyway, you may want to remove the rad completely as this will allow easier cleaning.
A word of caution: If you're using a very aggressive jet of water make sure you spray the rad fins straight on or you may bend them.
Since cleaning the rad my car runs much cooler. Before, the low speed fan could not keep the coolant temps down... the high speed fans would kick in! Now the low speed fan hauls the coolant temp down with ease. No more listening to the high speed fans wooshing away for no reason, I can't even tell the fans are running now unless I'm watching the coolant temp gauge.
Note, this is all observed with the AC off. With the AC on the fans run all the time.
Old Sep 21, 2011 | 11:49 AM
bartsky's Avatar
bartsky
Originally Posted by cdkcorvette7
Answers in Blue
Good info! Thank you...
Old Sep 21, 2011 | 11:51 AM
bartsky's Avatar
bartsky
Thank you, and I have been watching these. I have a customer that owns a speed shop here, and is going to change my fan settings for free. I'm going to see how that works first.
Old Sep 21, 2011 | 11:53 AM
bartsky's Avatar
bartsky
That's the first thing I check on any Vette I get. It is amazing the amount of debris they can accumulate there. This one was virtually spotless. Thanks for the info...
Old Sep 21, 2011 | 01:21 PM
SacCityCorvette
Supporting Vendor
Thats cool! Free works!
Old Sep 21, 2011 | 01:47 PM
bartsky's Avatar
bartsky
Well I gave him $30 of his car payment, have to be fair...
Old May 5, 2014 | 10:34 PM
STPSZ's Avatar
STPSZ
I know this thread is 3 years old but... I'd like to lower engine temps when parked or in slow traffic by reprogramming fans to come on sooner. Is there anyone in Chicago/Illinois area that does that?
To Reprogram Fans 03 Z06?
