Losing tire pressure
Old Sep 22, 2011 | 10:30 AM
Mew2's Avatar
Mew2
Default Losing tire pressure
Hey guys I've noticed lately my back left tire seems to loose air pressure over the course of a week or two I refill it and it drives fine. Any suggestions on what it could be? I'm using the stock tires and size
Thanks!
Old Sep 22, 2011 | 10:57 AM
chaase's Avatar
chaase
St. Jude Donor '12
Take it a tire place, have them pull it off the car and check for leaks.
Old Sep 22, 2011 | 11:01 AM
87SAM's Avatar
87SAM
A hole in the tire, leak at the rim/tire interface, TPMS nut torqued to proper value, bad TPMS o-ring or valve stem leak. Would suggest using a tub of water to dunk the tire in (or at least a portion of it at a time) or take it to a tire shop.
Old Sep 22, 2011 | 11:03 AM
Jewjenk's Avatar
Jewjenk
OOPS, that's called common sense...................
Old Sep 22, 2011 | 11:23 PM
rws.1's Avatar
rws.1
or it could just be it is getting cooler outside.
PV=nRt
tire pressure drops when the ambient temperature does.
Old Sep 22, 2011 | 11:42 PM
65GGvert's Avatar
65GGvert
PV=nRt
I guess the back left tire could be farther north than the other three and the temperature way up there is lower, so it only affects the one tire.
Old Sep 22, 2011 | 11:58 PM
jrose7004's Avatar
jrose7004
If they're thin spoke wheels, they might have a crack that's leaking.
Old Sep 23, 2011 | 12:26 AM
lucky131969's Avatar
lucky131969
Seriously?
Old Sep 23, 2011 | 12:43 AM
vettedude521's Avatar
vettedude521
My 99 has the same problem (same tire) I am pretty sure its the tpms sensor o ring or seat. It never leaked prior to having the tire shop rebuild them when I bought new tires. Not consistant either, sometimes I'll lose 10 lbs in 2 weeks. Sometimes none!! I just havent taken the time to take it in to Discount tire
Old Sep 23, 2011 | 08:45 AM
sjbrothers's Avatar
sjbrothers
I had the same problem with my 98 after I changed tires. The problem went away when I bought new rims and had all four tires put on the rims. I think it was fixed by the remounting but there are a lot of variables as mentioned above. You could try the easy ones first which is tighten the tpms nut first.
To Losing tire pressure
