Oil %
Old Sep 23, 2011 | 08:38 AM
sccs's Avatar
sccs
Default Oil %
Hello there,
I had an oil change 1 week back, car computer said 28% oil when we added 5liter of oil it said 56% and the stick showed minimum.. or.. like there was no oil at all.. added 1 more liter, and the stick now shows normal.
But the computer in car says now 27% oil!!! showed only once 56% =(
so now i have 6 Liters of Mobile1 5w30 oil. I reseted the % and then was blank, after time it showed 27% again!!
The car has 190k Kilometers/118k milles on te clock, and it's an 1998 C5 corvette, ls1.
Might be a bad sensor or something? i have no idea.
Old Sep 23, 2011 | 08:42 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Are you sure that the oil life monitor was reset correctly?
Old Sep 23, 2011 | 08:46 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
never heard that one before
Old Sep 23, 2011 | 08:49 AM
FNFastZ06's Avatar
FNFastZ06
The percentage is oil life remaining, not quantity of oil in the pan. Your engine should hold about 6.5 qts with a filter change.
You must reset the DIC with the key turned to on, but not starting the car, or it will revert to the last oil life %
Old Sep 23, 2011 | 08:52 AM
sccs's Avatar
sccs
ooo i see hehe.
i was reseting around while driving.. ill try this
hope it works
Old Sep 23, 2011 | 08:56 AM
jrose7004's Avatar
jrose7004
You didn't put in enough oil but that has nothing to do with the oil life indicator on the DIC.
Old Sep 23, 2011 | 09:30 AM
Ultimate ride's Avatar
Ultimate ride
Read your owners manual. There is a lot of good information in there.
Old Sep 23, 2011 | 09:32 AM
lucky131969's Avatar
lucky131969
Originally Posted by sccs
ooo i see hehe.
hope it works
Still sounds like you don't understand. The oil life system is not measuring quantity....rather, it measures % life left between oil changes. This is explained in detail, in your owners manual......don't be afraid to read it.
Old Sep 23, 2011 | 10:30 AM
Quicksilver Vert 01
Default Owners Manual Download
And just case the OP doesn't have an owners manual, here's a free download pdf copy:
http://gmpartshouse.com/downloads/ma...98corvette.pdf
Old Sep 23, 2011 | 11:44 AM
mjoacim's Avatar
mjoacim
That's awesome!!! I didn't know that existed, lol. Thanks, man!!
Old Sep 23, 2011 | 11:59 AM
cdkcorvette7's Avatar
cdkcorvette7
Hello there,
Are you saying your Oil Life Indicator in the DIC changed by itself when you added oil? I don't think that's possible...
Old Sep 23, 2011 | 12:00 PM
Quicksilver Vert 01
Gene Culley, at The GM Parts House, deserves all the thanks!
Old Sep 23, 2011 | 06:26 PM
alankb's Avatar
alankb
turn key on, push gas pedal three times, turn key off. oil life monitor is reset.
Old Sep 23, 2011 | 07:26 PM
hotwheels57's Avatar
hotwheels57
The pedal must be depressed fully three times within five seconds...
Old Sep 24, 2011 | 01:29 AM
sccs's Avatar
sccs
*shy*
Yes the oil life on the DIC didnt want to reset ill read the owners manual to have more understanding on that, how ever, i reseted yesterday with key on, and now it says 99%. ill still add half liter when i get it.
It was just that i thought something was wrong.. but everything is ok. *shy*
Thank you!
Old Sep 24, 2011 | 01:40 AM
alankb's Avatar
alankb
Did you get your cooling problem taken care of? You may want to send your PCM to a tuner over here and get a 160* thermostat at the same time.
Old Sep 24, 2011 | 03:53 AM
sccs's Avatar
sccs
yeh i did already make pretty mutch milles only had 1 small small problem but take care of it in 1 day. only need to buy new coolant reservoir and ill be set for life
how ever on long trips on high way i can even see coolant temp at around 190 degree so im happy this got kinda solved!
To Oil %
Old Sep 24, 2011 | 06:46 AM
baxsom's Avatar
baxsom
why would it go from 27% to 56% and then back to 27%
Old Sep 24, 2011 | 06:49 AM
04blackice's Avatar
04blackice
Baffeling.did i spell that correctley
Old Sep 24, 2011 | 08:45 AM
Carcass's Avatar
Carcass
Must have a leak.......
I'm kidding- good thing he didn't keep adding oil till it went to 100%.....
