98 corvette head light motor
Old Sep 24, 2011 | 01:56 PM
Randy JENS's Avatar
Randy JENS
7th Gear
Default 98 corvette head light motor
I started having problems with the light going up all the time. I quit comming up yesturday then today it started working again but now when you turn tha lights off and it goes down the motor keepd runniing and makes ab bad sound like the gears are stripping then the motor stops could it be the control module and where id the module at thank Randy
Old Sep 24, 2011 | 02:29 PM
zz28zz's Avatar
zz28zz
This is a very common issue. Search for it. Long story short, the plastic gears are stripping out. You can order brass gears that will last pretty much forever. You may be able to rotate the large gear 180 degs and use the teeth on the other side for a while. I got abt 6 more months out of mine before switching to brass gears.
Old Sep 24, 2011 | 03:20 PM
Randy JENS's Avatar
Randy JENS
7th Gear
thanks about the gear I will get one it's nice when people get togeter and can help each other forms rock thanks again Randy
Old Sep 24, 2011 | 03:25 PM
k0ts's Avatar
k0ts
Most likely the motor gears.. Do you hear a grinding sound?? That would indicate gears.. Or it could be the motor controller but gears give more problems.
Old Sep 24, 2011 | 07:27 PM
Randy JENS's Avatar
Randy JENS
7th Gear
I have an other Question for you, I take three bolts out the forth is a nut the arm is with but arm is still stuck on the motor shaft. Is there somthing els I need to do to get it off the arm it is hard to see what I am dealing with, as well as not easy to get aroud in there anyway thanks Randy
Old Sep 24, 2011 | 11:16 PM
C5Enthusiast's Avatar
C5Enthusiast
Default Headlight motor gear replacement
I just finished doing this to both of my headlights last week. The control arm was only held on by the nut.
Old Sep 24, 2011 | 11:48 PM
zz28zz's Avatar
zz28zz
Yep, just the nut holding the arm on.
I was able to remove the arm, spin the manual **** so the shaft (where the arm attaches) rotates 180 degs, then re-install the arm (without removing the 3 bolts). This uses the other side of the plastic gear. You will still be using some of the same teeth since the arm rotates a little more than 180 degs during raise/lower operations, but with a little luck, the headlight will work until you can get replacement brass gears.
Also, there's some instructions on this site on how to better access the area by removing the plastic headlight shroud.
Old Sep 25, 2011 | 04:05 PM
Randy JENS's Avatar
Randy JENS
7th Gear
I took the bolt off but the arm does not want to come off I am afraid that if I pry on it will brake is that what you have to do thanks Randy
Old Sep 25, 2011 | 04:20 PM
Chicago1's Avatar
Chicago1
If you do a search for headlight motor replacement you will find a few links with step by step and pics. Im on my phone or id post a link. Yes that rod needs some love to get off.
Old Sep 25, 2011 | 04:27 PM
Randy JENS's Avatar
Randy JENS
7th Gear
Thanks I will do that.
To 98 corvette head light motor
