Rear Hub dimensions.
Old May 2, 2002 | 03:07 PM
gene284's Avatar
gene284
Default Rear Hub dimensions.
Perhaps somone has the rear suspension apart on their C5. We are in need of dimensions from a rear C5 hub for a special rear end conversion we are working on. Can you supply the length from the hub bearing mounting face (that goes against the outside of the knuckle) to the the outside hub face (that goes against the inside of the rotor)?
Also, the overall length from the inner most face to the outside face of the hub.
Do the inner splines match a C4 spindle?
Photos of the C5 rear hubs and spindles would be helpful for discussion/descriptions.
Thank you.
[Modified by gene284, 2:10 PM 5/2/2002]
