DIC Options Rotating Display
Old Sep 25, 2011 | 07:19 PM
chuckrbt's Avatar
chuckrbt
Default DIC Options Rotating Display
The car sat for 10 days while I was on vacation. Now when I drive it, the different settings under Options rotate through the DIC. This rotation is fast at first (one setting per second) and then slows down to rotating at a much slower sequence (1 minute or more). I have tried to reset the options with no luck. I thought it might be a low battery, so put it on a charger overnight, but the problem remains. None of the buttons (fuel, trip, etc) will respond either. I checked the fuses in the box under the passenger foot board and all are good with no signs of corrosion.
A search of the electrical sticky and this forum in general did not bring up any similar problems.
Any ideas would be greatfully appreciated.
Chuck
PS It is a 98 with 115K miles. No previous problems of this type since I bought it in 2000.
Old Sep 25, 2011 | 08:13 PM
65GGvert's Avatar
65GGvert
Sounds like the options button contacts are sticking and scrolling through the choices.
Old Sep 26, 2011 | 08:58 PM
chuckrbt's Avatar
chuckrbt
Default Thanks
Can this be fixed DIY or do I need to take it to the dealer?
Chuck
To DIC Options Rotating Display
